Water in forward and mid bilge
- Has thanked: 602 times
- Been thanked: 1311 times
Re: Water in forward and mid bilge
- dsolo
- Vessel Info: 1997 Carver 405 MY
454 EFI Crusaders
Name: La Belle ll - Location: Onekama, Michigan
- Has thanked: 68 times
- Been thanked: 25 times
Your right water is 49 degrees. The exhaust port is about 3 inches into the water. Don't sure how much lift I could get with lines? Do you know if there is wood core at that fitting? If so I would think it would require pulling and inspecting the core? Addressing whatever issues are discovered? I tried tightening the fasteners on the flange. They seemed a bit mushie. Couldn't feel a firm tightening?
Thanks for the input.
Vessel "LaBelle"
1997 Carver 405 MY
454 EFI Crusaders
- Been thanked: 1113 times
dsolo wrote:Source of the post Don't sure how much lift I could get with lines?
Or put something inflateable under that corner of the boat and pump enough air into it.
- dsolo
454 EFI Crusaders
Vessel "LaBelle"
1997 Carver 405 MY
454 EFI Crusaders
Hmmm... maybe someone else knows if there's a core in there?
The bad news is, it sounds like you need to pull the boat and repair it correctly, otherwise with a half as%ed repair you will be worried about it all season.
Good news is its early in the season. You should be able to pull, repair and splash before well before memorial day!
- dsolo
454 EFI Crusaders
It will be good to get things apart and inspect. I plan on doing both starboard and port.
Any advice on repairing is welcome.
Vessel "LaBelle"
1997 Carver 405 MY
454 EFI Crusaders
Wishful thinking maybe...
Let us know how you make out.
- dsolo
454 EFI Crusaders
Anyone with experience please pipe in.
We have strong winds and rain forecasted for the next couple days. Nothing will happen until weather permits.
Vessel "LaBelle"
1997 Carver 405 MY
454 EFI Crusaders
