Holding tank
- Has thanked: 78 times
- Been thanked: 1093 times
Re: Holding tank
- Roxanne
- Vessel Info: 1999 Carver 356
- Has thanked: 13 times
- Been thanked: 10 times
Re: Holding tank
- Roxanne
Re: Holding tank
- Has thanked: 598 times
- Been thanked: 1281 times
Re: Holding tank
You on salt water, or did the boat come from salt ?? Oh and is it vacuflush or electric macerator ?
One more thing ...on the colour matter, some waxes will alter the colour slightly...all normal...dont sweat it.
- Been thanked: 601 times
Re: Holding tank
- Roxanne
Re: Holding tank
Re: Holding tank
- Roxanne
Re: Holding tank
- Roxanne
Re: Holding tank
I'm not sure why our diagram isnt on the Carver website or the case of paperwork that came with our boat but anyway... There has obviously been leaking in the past. The compartment has about 1 inch of YUCK water in the bottom and old stains around the top. I checked the shower and that pump is running fine. I decided to unhook the filter because I had read that if the tank is more than 3/4 full and you take the boat out, it can back fill into the filter. We took the boat over to pump out and I unhooked the filter. OMG I almost lost my lunch at that point. Liquid poured out of the filter.
We pumped out and I put 5 gal of soap water through the toilet to go back to the tank hoping to clean it out a little. When we got back to the dock I used the shop vac and cleaned out the compartment. Then (after I priced new filters $130 x 2) I decided to DIY. I cut the SeaLand filter in half, another vomit point, and unpacked the solid wet contents. After I cleaned it out real well I used liquid cement to add a connection that I bought at home depot into the center. I made a small filter at the ends out of a kitchen sponge I had and filled in with activated charcoal from Pet Smart. screwed it together and put it back in. When I put it back in the compartment I put it in up on top of the plumbing instead of down at the bottom hoping that it would be harder for the tank to back up into it. I learned that you guys are amazing and if I keep reading and asking questions I can fix just about anything (that doesn't involve a chainsaw, I'm not allowed to play with that anymore
dont ask) The suction of the vacuum doesn't work well with the toilet when the filter is off. Duh. The leaking came from a lose connection around the filter (the tank side) and I made sure I tightened everything before I put it all back. This also solved the vacuum coming on every 20 minutes. We had gotten to the point where we turned it off after every flush just to avoid the noise and the possible motor damage. I also made a filter for the front tank. That filter is above the tank under the dinette and was not in a position that tank contents could back up into it so it was mostly still pieces of charcoal . (I guess?? Unless someone REALLY over filled the tank? and maybe it has no other place to go but out the vent hole and into the filter? Can that happen?? Also I did notice that the tank pumped out more contents with the filter unhooked. Our tank doesnt have a "release" valve and I am guessing that with a clogged filter it was hard to get all of the contents out of the tank. So So glad to sleep in a room with no toilet smell tonight. Thank you THANK YOU for helping me figure this all out.. I am happy (a little embarrassed that I thought the water tank was the holding tank) a little more educated about our new investment, a little more confident about taking her out on my own and the best part is this group of smarties!
[image][image][/image][/image]- nightsky
- Vessel Info: '94 Carver 390 cpmy
- Has thanked: 6 times
- Been thanked: 16 times
Re: Holding tank
