Volvo Penta 7.4L needed ASAP
Re: Volvo Penta 7.4L needed ASAP
Postby tomschauer » June 21st, 2017, 1:37 pm
I believe they also are stamped in the block at the rear center above the crank. But not 100% certain.
Postby bud37 » June 21st, 2017, 2:03 pm
Just to add to the above....any serial type id numbers will be stamped on machined surfaces....also try on the pads above where the circulating engine water pump bolts to the block.....
