Port engine problems
Been thanked: 246 times
Re: Port engine problems
Postby mjk1040 » July 27th, 2017, 8:48 pm
Would help to know which engines we are dealing with here. 1998's should be throttle bodied and not carbed. If ethanol gas was used anytime before u acquired her, problems could be abound with the fuel system. But then again electronic issues could be the cause.
John Easley
Vessel Info: Sold a 1986 42' Chris Craft Catalina. Looking for a 1999-2006 530 Voyager Pilothouse.
Has thanked: 5 times
Been thanked: 8 times
Postby John Easley » July 28th, 2017, 9:21 am
Another vote for it being fuel or spark related. If they are separate fuel tanks, it's a good idea about disconnecting the fuel line and sticking it in a five gallon gas can. That would eliminate the issue of a plugged vent. Also a good idea about checking for spark after the problem starts. Still, I'm betting it's fuel-related.
Jack Kolberg
Vessel Info: 1998 Carver 380 Santego
Postby Jack Kolberg » August 7th, 2017, 9:54 am
Thanks for the reply's folks. My mechanic finally talked to Crusader and it sounds like it is an oil sending switch that has a habit of shorting out when under load and shuts down the engine. We replaced it last week and the engine runs strong but a lot of rain kept us from testing it on the lake. The dealer we were talking to said he keeps a bunch of these switches on hand as it seems to be a common problem. I am not a mechanic so can't really speak to this, but sounds like a pretty simple fix. we'll see.
Thanks for the input. I will keep you posted.
