Need Owners Manual
plmuto
Vessel Info: 1984 carver 32 aft cabin
Re: Need Owners Manual
Postby plmuto » November 7th, 2019, 7:30 am
Cooler wrote:Source of the post plmuto - link to 84 owners manual. Same as Viper sent. You will need to get an actual service manual from the engine OEM. What specifically do you have for engines? You should contact Carver for OEM list on your boat. 8-) er
https://carveryachts.blob.core.windows. ... -cabin.pdf
I have the crusaders I believe 350's
Been thanked: 413 times
Postby Cooler » November 7th, 2019, 10:40 am
Well that's good. I have a manual for a 1995 350XL Crusader that I could send to you. It is not a full blown service manual, but the manual that comes with the boat at delivery. Although there may be some changes, Crusader was known for keeping things pretty consistent over the years. If you would like me to send it, just PM or Email your address. 8-) er
Postby km1125 » November 7th, 2019, 1:00 pm
plmuto wrote:Source of the post
When you specify "350", you should add "HP" or "CI", as Crusader made both and they are different and it will cause confusion if you don't.
I suspect yours are 350CI
The 350HP is based on the 454 C.I. engine and the 350 C.I. engine is rated around 270HP
Users browsing this forum: No registered users and 46 guests
