Buying 2006 Carver 44 MY
Huckleberry
Vessel Info: 2007 Carver 36ss .
2005 Carver 44 CPMY
Has thanked: 18 times
Been thanked: 6 times
Re: Buying 2006 Carver 44 MY
Postby Huckleberry » October 8th, 2017, 12:21 am
Friend just moved a 42 mariner from Mi. to Az. they removed the arch and had to remove rudders also ! None of this is unusual , that's why they are removable . Cost to move was 19500.00 not including crane and trailer at destination .
All this being said , mine is due for bottom paint this winter and I am trying to find a company that will haul it out , stand it and do the job at the marina to avoid having them remove the arch !
Huck
chetcuti
Vessel Info: looking to buy a Carver 44 aft cabin
Postby chetcuti » October 11th, 2017, 12:07 pm
Hi Huckleberry,
I understand that this is not that unusual but the key is to hire the competent Company!
Guychet
chetcuti
Postby chetcuti » October 19th, 2017, 10:00 pm
Midnightsun wrote:Source of the post I assume it is a 44 CMY (Cockpit Motor Yacht). That being said I do own a smaller version, although 1 year younger and same engines, a 41 CMY to be exact. The Volvos are not underpowered by any means in my boat and would assume they would be fine in the 44. You simply do not remove the arch. The hard top, wing doors and entire bridge need to come off and then put back on which is a huge job. Depending on where you live and how much they charge, I would budget in a minimum of $10,000 and maybe up to $18,000 to have her taken apart and put back together. You will also need to consider maybe 2 loads for transportation as I personally cannot see getting the disassembled parts on just 1 truck.
Hans,
Hans,
I finally had a look at the PICs of the disassemble and it looks like a big job but can be done with the right mover! Very helpful.
I haven't decided if I'm going ahead but I'm getting a quote from a Boat Mover that was recommended.
Cheers for now.
Guychet
Postby Midnightsun » October 20th, 2017, 5:54 am
Definitely can be done and the boat is set up to do so. They are delivered this way from the factory and wiring/hydraulics are all plug and play unless the owner added stuff which will need to be looked at and identified carefully. Only issue is getting the competent people to do the work. I was lucky as the move was only an hour drive or so as the boat was on a land locked lake. This made it possible for the same people who took it apart to put it back together which made things much easier.
