Fresh Water System Pump
Re: Fresh Water System Pump
Postby km1125 » December 13th, 2017, 2:51 pm
Viper wrote:km1125, I suspect you're talking about the V-Flo or something similar.
Went and looked it up. It was a ShurFlo Smart Sensor 4.0
amanphoto wrote:Source of the post This the the pic of the pump that is currently in the boat. I've changed the supply lines and cleaned the bilge. This is an old pic.
That looks very similar to my original pump. You might still be able to get replacement parts for the head on that, if you do end up keeping it in there and just want to get performance back to 'like new"
Postby Viper » December 13th, 2017, 5:58 pm
Same concept different brand
amanphoto
Has thanked: 3 times
Been thanked: 12 times
Postby amanphoto » December 16th, 2017, 7:10 pm
So my current pump is Shurflo 2088-423-344 : 2.8 GPH : 45 psi : 7.5 amps (no longer made)
I'm looking at either
Ultra Quiet Shurflo Motor home Water Pump 2: 3 GPH :55 psi : 7.5 amps : $110.
(built in check valve)
or
Remco pump 55-AQUAJET ARV : 3.5 GPH : 75-85 psi : 10 amps : $160.
(variable speed)
