Walter V Drive Systems Gearbox Q
- Has thanked: 602 times
- Been thanked: 1310 times
Re: Walter V Drive Systems Gearbox Q
To pressure test the cooling circuit, I cap off both raw water ends at the fittings. One of my plugs has an shrader valve on it which I use to attach a hand pump to with a gauge. You pump it up and see if it maintains pressure for a while. A drop in pressure means you have a raw water side leak either in through the housing, through the gasket to outside, through the gasket to the dipstick hole, or through the oil E tube.
- mjk1040
- Been thanked: 248 times
- SplashyLady
- Captain
- Has thanked: 20 times
- Been thanked: 88 times
https://www.motionindustries.com/motion ... 432371.jpg
Lake Norman, NC
Carver 3227 - "Splashy Lady"
- 390Express
- Captain
- Has thanked: 141 times
- Been thanked: 15 times
I got the ID tag off of the Walters Gear Drive, apparently my model is an RV 40. Allegedly it takes 2 quarts of fluid (4 pints). I guess that will tell me how much water got in there, presuming it was full/had proper fluid when the water was introduced. You are correct, the fluid in both looked exactly the same, same level, same water characteristics. I'm not as concerned about the water issue as I once was. I watched a video of a guy draining his fluid and it was way, way worse than mine. That said, I'm a bit torn on the non-detergent vs HD argument. Most people say it really doesn't matter, these things are bulletproof and any SAE 30 will work, others say go with the non-detergent, but the non-detergent oils tend to be poorer quality. Anyone have a fluid/brand that they recommend (or don't recommend)? I'm currently leaning toward Valvoline synthetic.
Trans is a BW velvet drive (thanks for the location of the ID tag), I plan on changing both the trans fluid and gearbox fluid this weekend. I would never splash a boat with an unknown maintenance history with old fluids in it. The BW velvet drive is 5 quarts (well, 4.9) of GM Dextron III trans fluid, correct? Is the only way to drain the BW velvet drive through the dip tube? I didn't see a drain plug, but it's a lot easier to find things crawling around down there when you know where to look.
There is a little crud on the prop shafts (thin layer of dried algae). I'm considering using a scouring pad (green pad) and some simple green to clean them off. Any issues? The sacrificial anode just clamps onto the shaft, and I don't need to worry about it being off balance or anything? Coming from the performance boating world, this seems weird to me.
The boat has a fluid mechanism connected to the prop shaft seal. Do I need to do anything with this? I'm familiar with the old school rope seals, this is my first go-round with this system. (pics attached)
- mjk1040
Oval shaft anodes are common in recreational applications. It was pretty common years ago to use zinc anodes even in fresh water so you should check which type you have. If their surface is relatively smooth and they seem to still be full size, replace them as they are likely zinc and aren't doing a thing to protect your running gear. To be safe, I'd replace them. You could go magnesium for the highest protection as they are the most active but they are expensive and you'll need to replace them every year. I use aluminum on all inboard applications now in fresh water. They are less active but are just fine for inboard metals, much cheaper than magnesium, and will likely last 2-3 years. If you have anodes on any other gear like rudders and trim tabs, you must replace them as well so that all anodes are of the same metal composition.
- 390Express
- Captain
Viper wrote:Source of the post The shaft seal uses ATF. The trend now is to replace those units though with water cooled ones to keep oil out of our waters.
Ha, thanks Viper. I'm pretty environmentally conscious, but I'm more worried about keeping water out of my boat than anything. I mean, think of the environmental consequence of having to build a whole new boat! (I'm kidding, somewhat) Is there any maintenance that I need to do to the prop shaft seal, or just splash it and see where its at?I've heard of people replacing prop shaft seals with the boat in the water, but I don't know how keen I am to that idea.
I'll look into aluminum anodes. The prop shafts are stainless and have zero corrosion, the props are brass/bronze and have no corrosion as well. If I was trying to protect an aluminum outdrive, I may consider magnesium, given how fast aluminum corrodes, but I agree with you, I'll look into and most likely purchase aluminum anodes before I hit the water. Prop shafts on this thing are huge (1.75). I think the shafts on our 34 Sundancer were 1". I'm a bit surprised how much "beefier" this boat is.
- 390Express
- Captain
My biggest issue at this point seems to be the fuel. I took the gas line off of the fuel / water separator and it didn't smell like gas. It wasn't "varnish" or tarry, but it had a strong, sweet alcohol smell to it. Kind of smelled like anti-freeze and alcohol mixed together. In any event, it needs to come out. There are no fittings at the bottom of the gas tank, and nothing comes out when I took the fuel line off of the water separator. I'm considering hard wiring a separate fuel pump, hooking it to the line that comes out of the water separator, and drawing it out that way. Thoughts?
If that turns out to be the best option, does anyone know what size fitting I need to hook the line to the fuel pump? I just want a barbed fitting that I can screw into the gas line fitting, to connect it to a rubber hose on the pump. To the extent it helps, a 3/4 in wrench is what I used to disconnect the fuel line from the fuel water separator.
I tried feeding a 3/8 tube into the tank from the fill valve, and it was a no-go. I'd rather stay out of the bilge if possible. Lots of smells down there, it needs a good cleaning. It's not particularly filthy, but lots of solvents and PB Blaster sprayed at various times over the last few months. I get a headache down there. Removed the starters and alternators this weekend too. More preventative than anything. I'm having both rebuilt. Should have them back later today or tomorrow. The other option is to try to remove the approximately 2" inlet hose at the top, and stick something directly in the tank.
What is the round plastic thing near the fuel water separator? A vent for the gas tank I presume?
Thanks for the advice so far!
