2001 Carver 444 AC
Re: 2001 Carver 444 AC
Postby bud37 » June 5th, 2018, 4:20 pm
Check and clean all your filters/ return air intake screens etc.......
Postby km1125 » June 5th, 2018, 4:45 pm
Is your sea water pump coming on and flowing water before your compressors start? You may just have to prime the system.
Topic author
Tomion
Vessel Info: Carver 530
Been thanked: 2 times
Postby Tomion » June 5th, 2018, 5:03 pm
Thanks will check both.
Postby tomschauer » June 5th, 2018, 11:35 pm
Sounds like they are locking out on lack of water flow.
As others have mentioned, you may need to prime or bleed the condenser water pump. You should have water coming out of at least two through hull fittings on your 530 when the a/c pump is running.
