444/44/396 turbo not spooling up
Huckleberry
Vessel Info: 2007 Carver 36ss .
2005 Carver 44 CPMY
Has thanked: 18 times
Been thanked: 6 times
Re: 444/44/396 turbo not spooling up
Postby Huckleberry » November 13th, 2018, 6:19 pm
Thanks V57 . I am anxious to try your suggestions . The boat has been on the hard for two months :-( . Hopefully it will be back in its slip in the nest week or so , so I can start checking . To your knowledge (you seem to have a lot) is there anything they could have disconnected or broke while removing & installing the new air filter ?
Huck
voyager57
Vessel Info: 2002 57' Voyager Pilothouse
Been thanked: 2 times
Postby voyager57 » November 13th, 2018, 8:12 pm
There's nothing they could have broken if only replacing the air filter. It literally just sits in a metal sleeve in front of the turbo air intake. Once you pull the filter out and look in there you'll see what I mean.
Huckleberry
2005 Carver 44 CPMY
Postby Huckleberry » January 4th, 2019, 12:50 am
Still waiting for boat to get back from shop and in the water so I can get this figured out . :angry:
Huck
Huckleberry
2005 Carver 44 CPMY
Postby Huckleberry » March 28th, 2019, 2:09 am
Yeah ! Problem found and fixed ! The hose between the turbo and the manifold somehow just slightly slipped off on one side . Clamps were not tight enough . This caused the turbo to have no boost effect . Slid id back up , tightened hose clamps and problem solved ! Thanks everyone for your input and suggestions .
Huck
Been thanked: 1180 times
Postby Midnightsun » March 28th, 2019, 4:22 am
Gotta love it when the solution is so simple not to mention inexpensive. If you can, post a picture of the hose/clamp in question. Thanks for posting.
Has thanked: 469 times
Been thanked: 1765 times
Postby Viper » March 28th, 2019, 6:50 am
Thanks for the follow up. Glad it was an easy fix that didn't cost anything, those are the best! :down:
Huckleberry
2005 Carver 44 CPMY
Postby Huckleberry » March 29th, 2019, 12:48 am
Sorry , I can't figure out how to add or insert a picture .
Huck
Has thanked: 598 times
Been thanked: 1281 times
Postby bud37 » March 29th, 2019, 10:27 am
Right below where it says Preview Submit there is an add files box, to the left.....just click and follow instructions as to where to upload the desired file from.
Huckleberry
2005 Carver 44 CPMY
Postby Huckleberry » March 30th, 2019, 2:34 am
Hard to see but the red hose should be down over the white collar .
Huck
Users browsing this forum: No registered users and 5 guests
