Drilling thru a thick swim platform
Pete
Vessel Info: 2001 Carver 444 diesels
Has thanked: 56 times
Been thanked: 15 times
Re: Drilling thru a thick swim platform
Postby Pete » January 23rd, 2020, 8:42 pm
Tireless wrote:Source of the post I am in the process of installing a Sea Weed davit system on the swim platform of my 2006 44 CMY. The swim platform is made of two layers of laminated fibreglass with a one inch thick balsa core sandwiched in between. I have access to the lower part of the swim platform from the bildge area under my cockpit floor. It is hard to believe your swim platform would be 10 inches thick. There must be a void under the top surface of your platform and the hull. In my instance, I plan on drilling over sized holes(1/4" larger) through the deck and removing 1/4 " more balsa core in-between the 2 fibreglass layers. I will then fill with Six10 epoxy and let it harden. I will drill out a 5/16" hole in the hardened epoxy to accommodate the 1/4" through bolts. I am sealing with 3M 4200 as well. I don't want to run the risk of water intrusion into the core, as it will wick and destroy the platform. The epoxy plug also will give a better compression factor between the backing plates and the hardware than the balsa core on its own. I assisted a friend in installing the system you have and the holes must be very precise or the upper plate will not slide on and off. Hope this helps you.
As stated by bud37, if you can't get access and see what's going on under your swim platform, Carver will know how that's put together, 1-920-822-3214 and ask for Brian. He's very helpful and can pull up your plans.
Greg, sorry to bounce between posts,
I just came across this description of what you did but I'm guessing the backing plates are angled and the nuts are not flush with the plates?
2001 444
The best way to improve your memory is to do unforgettable things.
Pete
Postby Pete » January 23rd, 2020, 8:44 pm
spsu00 wrote:Source of the post We bought the Hurley H3O David system to install on our Carver 410. We are having to use the Davit extension and it requires "8"
Holes be drilled they the swim platform for the bolts. The swim platform on our boat where we need to drill is almost 10" thick. Does anyone know if this swim platform is hollow core ? Is there anything I should look for before I start drilling or any advice on drilling?
Do you have pictures of your install including your mounting bolts?
2001 444
