New Boat Owner - Need help with kohler Generator.
mobinakhtar
Vessel Info: 2003 Viking Princess 65
1988 Carver 3207 Convertible
1971 Hatteras 38 Convertible
2005 Boston Whaler 15 Montauk
Been thanked: 7 times
Re: New Boat Owner - Need help with kohler Generator.
Postby mobinakhtar » June 14th, 2019, 9:20 am
Bud37, I do not see the ground wire and my engineer friend also expressed concern about one missing. I will take close up pics of the solenoid next time showing wires.
Has thanked: 603 times
Postby bud37 » June 14th, 2019, 10:33 am
mobinakhtar wrote:Source of the post Bud37, I do not see the ground wire and my engineer friend also expressed concern about one missing. I will take close up pics of the solenoid next time showing wires.
You have a bigger unit than the one I have therefore perhaps not exactly the same, but I think if you follow the ground ( black cable from the battery negative) back to the generator you will see if there are any connections, corrosion etc and how it is grounded to double check as that area under the unit can be fairly dirty.
Just cross the simple no cost things off the list first.
kamakazerc
Vessel Info: proud new owners of a 1988 3607 aft cabin,as of august 2018, and still have at this time our 1980 mariner 2896
Has thanked: 3 times
Been thanked: 8 times
Postby kamakazerc » August 12th, 2019, 3:53 pm
If you can crank it by jumping the solenoid than probably not the ground or the solenoid! But still worth cking and cleaning. I'm going with bad relay under the black box, and or maybe just dirty connections at the relay....
Good luck !!!!
Been thanked: 285 times
Postby buster53 » August 12th, 2019, 6:34 pm
kamakazerc wrote:Source of the post If you can crank it by jumping the solenoid than probably not the ground or the solenoid! But still worth cking and cleaning. I'm going with bad relay under the black box, and or maybe just dirty connections at the relay....
Good luck !!!!
We haven't heard from the OP in two months. No idea if he resolved his problem
mobinakhtar
Postby mobinakhtar » August 13th, 2019, 11:00 am
Not yet. A Koehler tech is looking st it. Says needs some control board. Part ordered 2 weeks ago. I am traveling so will post status in a week or so when I return to Houston
mobinakhtar
Postby mobinakhtar » December 10th, 2021, 12:08 am
I think I got taken by this tech guy. H charges almost 7K but got the genny going. replaced entire fuel system, eelctricals, and electronics except the engine (meaning he didnt know shit and swapped everything for new). I basically had to pay 7K to get my gas genny back from him. at least it works now.
Update 12/1/2020 - sold the carver. Bought a 65' 2003 Viking. Big upgrade :)
Postby Viper » December 10th, 2021, 7:09 am
Thanks for following up. Congrats on the Viking, nice boat.
Postby km1125 » December 10th, 2021, 11:34 am
mobinakhtar wrote:Source of the post I think I got taken by this tech guy. H charges almost 7K but got the genny going. replaced entire fuel system, eelctricals, and electronics except the engine (meaning he didnt know shit and swapped everything for new). I basically had to pay 7K to get my gas genny back from him. at least it works now.
YIKES! Yes, I think that tech guy needs a lesson in troubleshooting!! Aside from the control board, they are not very complicated.
Congrats on the Viking!! Those are nice boats! (er, SHIPS!)
