New Inverter/House Bank
vineyardgray
Has thanked: 128 times
Been thanked: 33 times
Re: New Inverter/House Bank
Postby vineyardgray » September 27th, 2019, 8:40 pm
You can see I temporarily wired in one of these while doing the install - one cannot be without tunes:
M/V Gilded Splinter
1988 Carver
3867 Santego
PCYC
vineyardgray
Postby vineyardgray » September 27th, 2019, 8:48 pm
I had to pop some new holes in the bulkhead between the cabin and the engine bay for the battery cables to pass, you can see the 1/0 battery cables are doubled for + and -
These holes are alongside an existing hole that was never sealed from factory (I assume) - I was going to use duct seal to plug them but could use silicone - thoughts?
M/V Gilded Splinter
1988 Carver
3867 Santego
PCYC
vineyardgray
Postby vineyardgray » September 27th, 2019, 8:51 pm
The doubled up cables are a nuisance - I had intended to use the lugs 'back to back' but because I'm using power lugs instead of light battery lugs they didn't want to fit that way so I ended up with this crap:
In retrospect maybe should have just gone single 4/0?
M/V Gilded Splinter
1988 Carver
3867 Santego
PCYC
Postby Viper » September 27th, 2019, 8:52 pm
I was getting concerned because that unit is not rated for installation in a gasoline engine bay. Technically, neither is the fuse in the picture. Have you confirmed the minimum wire gauge for the length of the circuit at the inverter's max load? I see you're using doubled up 1/0 wire. Is this correct?
vineyardgray
Postby vineyardgray » September 27th, 2019, 8:54 pm
Battery monitor now lives where the old useless Volt meter used to be (Batt 1/Batt2 switch now defunct - just a hole filler at the mo)
M/V Gilded Splinter
1988 Carver
3867 Santego
PCYC
vineyardgray
Postby vineyardgray » September 27th, 2019, 9:05 pm
Just a rant about this stupid thing - if the most important range of a battery bank is from 10 volts to 15 volts, why did they make the gauge markings/graduations go down to zero and make more than 50% of the meter useless?
M/V Gilded Splinter
1988 Carver
3867 Santego
PCYC
vineyardgray
Postby vineyardgray » September 27th, 2019, 9:06 pm
This is much better:
M/V Gilded Splinter
1988 Carver
3867 Santego
PCYC
Postby bud37 » September 27th, 2019, 9:07 pm
That spot you have for the inverter.....will it have some air movement to cool the inverter ?
That gage looks like it may have been a replacement at some point.
vineyardgray
Postby vineyardgray » September 27th, 2019, 9:13 pm
Viper wrote:Source of the post I was getting concerned because that unit is not rated for installation in a gasoline engine bay. Technically, neither is the fuse in the picture. Have you confirmed the minimum wire gauge for the length of the circuit at the inverter's max load? I see you're using doubled up 1/0 wire. Is this correct?
I have spoken to folks who assured me that dual 1/0 will be more than sufficient and indeed it does match what Victron has in their specifications. I hope that it is right - I will get a marine electrician to bless the install after it is fully complete.
M/V Gilded Splinter
1988 Carver
3867 Santego
PCYC
vineyardgray
Postby vineyardgray » September 27th, 2019, 9:19 pm
bud37 wrote:Source of the post That spot you have for the inverter.....will it have some air movement to cool the inverter ?
Yes, the area down there is quite frosty as the un-insulated air conditioning duct routes through that wall and keeps that low cabinet nicely chilled. I will also install louvered doors do promote airflow :approve:
I can assure you it is bone stock along with the other 6 analog meters :confused:
M/V Gilded Splinter
1988 Carver
3867 Santego
PCYC
