396 Aft waste tank hose access
paulr
Vessel Info: 396 CY Aft Cabin 2001 8.1 Crusaders
Has thanked: 56 times
Been thanked: 32 times
Re: 396 Aft waste tank hose access
Postby paulr » May 20th, 2023, 9:02 am
Thanks for the detailed post. It has given me hope that I can fix a serious problem on my recently acquired 2001 396.
I can't pump out the aft waste tank as the vacuum pump just seem to suck air. I checked the inspection plate under to deck plateand it is connected. Looks like I need to follow it all the back to the tank.
Does anyone have experience with this particular hose?
Postby bud37 » May 20th, 2023, 1:05 pm
Hoses can get kinked over time with the heat cycles etc.......here is a stupid question maybe, but, have you checked the tank itself.......maybe all hard from disuse, or already empty.
paulr
Postby paulr » June 11th, 2023, 9:07 pm
I just replaced a portion of the deck waste overboard pump out hose.
The reason being it did not work, it sucked air. (this is the first time I tried to use as I just recently bought the boat). The connection to the rigid PVC pipe to the pump hose was not accessible so I cut the ridged pipe and glued in a new fitting.
See the photos of the access plate under the carpet in the aft state room closet.
The job took about 1-1/2 hours. I have a feeling Carver put the fittings in the wrong place because the fittings were not under the access plate in the closet.
No reason to mess with the exhaust hose. Now I can use both heads
