Help on boat find
Has thanked: 469 times
Been thanked: 1765 times
Re: Help on boat find
Postby Viper » November 16th, 2019, 9:18 am
Tommy3 wrote:Source of the post Hey Viper..... You think current owner is ok with a survey on a 2k$ boat?
As others have alluded to, it's not about the owner, it's for your benefit for all the reasons mentioned above. Perhaps other than a timing issue for a quick sale, he'd only have a problem with a survey if he were trying to hide something IMO.
Has thanked: 78 times
Been thanked: 1093 times
Postby km1125 » November 16th, 2019, 5:18 pm
To me, the real deal-killer would be a soft transom. Most of the other stuff - like a soft deck - you can take care of if you are handy at all. Redoing a transom is 10x harder.
Been thanked: 284 times
Postby buster53 » November 16th, 2019, 8:00 pm
Tommy3 wrote:All,
Thanks so much for the input. Will decide today. I believe book value according to NADA is about $9K.
What is your opinions of Carver?
So, what's the scoop? Inquiring minds want to know.
Tommy3
Vessel Info: 1982 25ft Fiberform
1975 20 ft Thompson
1969 17ft Sportcraft
1968 19ft Seastar
Been thanked: 3 times
Postby Tommy3 » November 17th, 2019, 6:53 am
Good morning,
Todays the day. I will keep you posted. In regards to soft transom. You can feel by touch?
Postby Viper » November 17th, 2019, 8:10 am
No you have to do a sounding and use a moisture meter.
Postby buster53 » November 18th, 2019, 8:28 am
Tommy3 wrote:Source of the post Good morning,
That's why you need a survey.
Tommy3
1975 20 ft Thompson
1968 19ft Seastar
Postby Tommy3 » January 18th, 2020, 7:33 am
HI guys,
So after being at mechanic, the water in engine is a blown head gasket. Mechanic says he can clean both heads, lap valves etc, do a few oil changes and should be fine. Intake, risers, manifolds he say look good. Outdrive needs bearing carrier assembly. Expensive part (450.00) but ok with because outdrive looks good.
THE BAD NEWS....
Was told stringers are soft under engine. Fiberglass guy wants 3000.00 to replace two stringers in bilge under engine. Do you guys know of a cheaper fix?
ALSO...
Mechanic noticed two cracks in interior transom assembly. 2800.00 for that. He feels transom is not bad as far as softness.
What are your thoughts please[image][/image]
Has thanked: 598 times
Been thanked: 1281 times
Postby bud37 » January 18th, 2020, 8:59 am
Have you already purchased this boat ?
Tommy3
1975 20 ft Thompson
1968 19ft Seastar
Postby Tommy3 » January 18th, 2020, 9:29 am
Yes for $1500.00
Been thanked: 601 times
Postby tomschauer » January 18th, 2020, 11:07 am
The bad news, if that engine sat with water in it, its going to need a lot more than a valve job. When you add in the other repairs that you know of, your talking about putting 8k into a boat that's worth 5k on the top end in great condition. Not good math. If it came with the trailer, sell the trailer for 2k scrap the boat and start your search over.
