Looking for side hull ventilation covers for 1983 Carver 3607 Aft Cabin
Used boat parts, used Carver boat parts, trailers, dinghies, outboards, props...everything but the boats they were attached to. ALL ADS ARE FREE - USERS MUST HAVE AT LEAST 10 POSTS TO PLACE AN AD
Forum rules
All classified ads for boat parts are free. Please be as specific as possible in describing your item. You can upload pictures too!
CarverYachtOwners.com and the owners of this forum take no responsibility for the authenticity of ads or legitimacy of items being sold. Buyers, please buy responsibly.
To place an ad start a new Topic. We reserve the right to delete ads from users with fewer than 10 posts.
Re: Looking for side hull ventilation covers for 1983 Carver 3607 Aft Cabin
Postby km1125 » January 17th, 2020, 8:02 pm
tomschauer wrote:Source of the post Just an FYI, as I doubt anyone other than a surveyor would notice, but you are required to have a dedicated bilge blower for each gasoline propulsion engine. Two engines, two separate blowers.
Is that a USCG requirement or just an ABYC requirement? I don't think I've ever heard of that under the USCG, just that there needs to be "sufficient" forced ventilation.
In my older copy of the ABYC rules it says more than one blower may be used, but there is no requirement I can see for more than one, if one will suffice.
Postby tomschauer » January 18th, 2020, 12:35 am
KM, I believe I read on a boat US article that it was a USCG requirement. It looks like either I misread or Boat US was mistaken (most likely my mistake). A quick search shows an individual blower is required for each "compartment" not each engine.
https://www.uscgboating.org/regulations ... LATION.pdf
Skydancer
Vessel Info: 1983 Carver 3607 Aft Cabin
Twin Crusader 350s (454 cui)
Has thanked: 109 times
Been thanked: 4 times
Postby Skydancer » January 27th, 2020, 5:31 pm
Thanks for the information.
Could you please provide the Code requiring two (2) blowers that you refer to?
I have researched the USCG Boat Builder's Handbook; and the powered ventilation requirement is based solely on engine compartment Cubic Feet (less the cubic ft space occupied by permanently installed equipment). No mention is made of the number of engines; only CFM requirement based on space dimension. They state that this CFM requirement can be satisfied by One (1) or more blowers - as desired.
The CFM provided by the 4" blower that I installed exceeds the USCG requirement for my engine space.
Additionally; I created a wiring circuit that allows me to operate the Blower manually prior to starting either the main engines or the generator, and once the engines (and/or generator) start, the circuit switches to "automatic" and the blower continues to run as long as the engines (and/or generator) are operating - regardless of the position of the "manual switch". I just leave the Manual Switch enabled so that when I shut down the engine the blower continues to run until I turn the manual switch off.
Return to “Boat Parts For Sale”
