3607 Upper Helm Access
Winegrapewill
Vessel Info: 1989 3607 Aft Cabin
Has thanked: 3 times
Re: 3607 Upper Helm Access
Postby Winegrapewill » March 18th, 2020, 9:48 am
The thought had crossed my mind to add a fuse block and eliminate all the inline stuff for radio, chart plotter, etc . . . It would make finding the right one alot easier.
Postby km1125 » March 18th, 2020, 7:55 pm
Winegrapewill wrote:Source of the post The thought had crossed my mind to add a fuse block and eliminate all the inline stuff for radio, chart plotter, etc . . . It would make finding the right one alot easier.
What I am going to do (not done yet) is put a fuse block inside the cabinet just to the port side of the bridge helm. Run the large "bridge" +12V feed to that and use it to power all the accessories up there. Then it's easy to get to without pulling screws and the wiring would be very short. I mounted a radio/cd just above the doors to that cabinet too.
I did a similar thing in the lower helm. If you have a lower station, look in the projects forum. I put a sliding door in that panel below the lower helm and mounted a fuse block behind it (same model block I bought for the upper helm), so you can get to is easily, but it's "out of sight/out of mind" otherwise. There is one large (10ga?) +12v wire for the helm and for the bridge coming directly from separate breakers in the main panel.
Postby Viper » March 19th, 2020, 6:43 am
Been thanked: 490 times
Postby waybomb » March 19th, 2020, 12:44 pm
Buy something that can be mounted outside the well. You don;t want to be removing the well everytime you blow a fuse, especially if underway
Postby km1125 » March 20th, 2020, 2:01 pm
Those are the exact ones I have for both the upper and lower station.
Postby Viper » March 21st, 2020, 8:44 am
Ya short of getting a breaker panel which is way more expensive, these are just great. Get the 12 circuit one instead of the six, you'd be surprised at how quickly you can use them all up when you start adding more toys.
Postby RGrew176 » March 21st, 2020, 11:45 pm
My boat is old enough to use the glass fuses. I do have a pretty good supply aboard.
