Potable Water Pump Continuously Running
Marty
Vessel Info: 2000 326 AFT Cabin
Has thanked: 16 times
Been thanked: 9 times
Re: Potable Water Pump Continuously Running
Postby Marty » June 23rd, 2020, 3:21 pm
Yeah the current pump is a SHURFLO 39010216 - 12V, 7.5A 55 PSI, 5 AMP Max and 3 GPM - ignition protected- Replacement is 4138-111-E65 for around $200 best I can find on Amazon.
Marty
Postby Marty » July 1st, 2020, 7:59 am
Back up at the boat and found a small drip at the intake for the pump at the FPT connector. Will swap that out and hopefully it will correct the cycling of the pump continuously
Marty
Postby Marty » July 24th, 2020, 8:31 am
Changed a couple fittings as there was evidence of a small leak, but did not fix the issue. Ended up replacing the pump and that was the issue. Original pump so it was 20+ years old.
Been thanked: 1111 times
Postby km1125 » July 24th, 2020, 9:48 am
If you're curious, take the old pump apart. You'll probably find some "gunk" on the valves and you can clean them and put it together and it'll probably work fine again... and you can keep it as a spare.
Marty
Postby Marty » July 24th, 2020, 11:49 am
Great idea.....I was going to dumpster it.
Marty
Postby Marty » July 26th, 2020, 6:22 am
Thanks for the advice KM1125. Looks like I will have a decent spare. Opened the pump up and there was a piece of plastic stuck in it. Based on how/where the pump was mounted it was impossible to work on so remove and replace was the best option.
Postby Viper » July 26th, 2020, 10:26 am
Thanks for following up Marty.
Postby km1125 » July 26th, 2020, 8:29 pm
I'm glad to hear you got it fixed. Even if you didn't though, I think it's pretty fun finding out what actually happened that caused something to stop working.
You might find a lot of other uses for it too... like a portable wash-down pump or a boat sprinkler to get the little kids wet!!
rjr
Vessel Info: 440 MY
Has thanked: 25 times
Postby rjr » August 2nd, 2020, 6:33 am
Mistake
Marty
Postby Marty » August 2nd, 2020, 5:09 pm
rjr wrote:Source of the post Mistake
HUH?
