Dock water supply
- Mkmohn
- Vessel Info: 2000 396
- Has thanked: 15 times
Re: Dock water supply
- pepmyster
8.1 Volvo Penta
- Has thanked: 492 times
- Been thanked: 210 times
It is my understanding older Carvers have an in line check valve right after the inlet unlike the all in one Shurflo unit on mine.
Mkmohn wrote:Source of the post I did replace the dockside inlet and the result was a minimal improvement of interior water pressure.
You haven't mentioned in any post whether the water pressure is okay or just as low when operating from your on board water tank. This makes a difference in the diagnosis process.
Hans suggested checking pressure at the dock pedestal, have you confirmed it yet?
Can you post a picture of your old original inlet fitting? This is important as we shouldn't assume it's factory original given there is more than one way of plumbing a regulated dockside water inlet system.
- TruckerTim
- Vessel Info: 2000 Voyager 450
Sarasota, FL - Has thanked: 1 time
TruckerTim wrote:Source of the post Old post but can someone who has replaced the dockside inlet tell me where you purchased it from? I have a 2000 450 Voyager and connection does not seal to the water hose so I'd like to replace. Thanks
Have you checked that the seal is still in place? Same round rubber ring one finds in a regular garden hose setup.
- TruckerTim
Midnightsun wrote:Source of the postTruckerTim wrote:Source of the post Old post but can someone who has replaced the dockside inlet tell me where you purchased it from? I have a 2000 450 Voyager and connection does not seal to the water hose so I'd like to replace. Thanks
I did and it was so I replaced. Still leaking where the metal fitting screws into the hose end. Thanks
