Timer on 2807
Re: Timer on 2807
- Been thanked: 1111 times
Re: Timer on 2807
Davepjr wrote:Source of the post .... this year I had decided to have the mechanics change the element and they said no that it was too far gone and I need to replace the whole thing.
My boat is an '83 and the original water heater still works just fine. Since yours is on a timer I suspect it has even less hours than mine does and could last quite a long time.
Viper wrote:...So out of curiosity, how does this work? You set the timer for a certain length of time and then it shuts the power off to the heater after that, and you have to reset every time you want hot water, or want it at a different time? And as Hans mentioned, how does it know what time it is if you keep disconnecting shore power, you have to reset the current real time when back at a dock? Am I missing something here?
It's just a simple mechanical timer. I'm not sure exactly which one the OP has, but it can be a 1hr, 2 hr or 12 hr timer that just shuts off when time expires. You set it to whatever time (minimum of 20 minutes) that you think you'll be needing hot water. You could set it for 12 hours and you'd have hot water for the next morning and you could reset it before it even expires if you need hot water the rest of the day.
Re: Timer on 2807
Re: Timer on 2807
km1125 wrote:Source of the post.....It's just a simple mechanical timer. I'm not sure exactly which one the OP has, but it can be a 1hr, 2 hr or 12 hr timer that just shuts off when time expires. You set it to whatever time (minimum of 20 minutes) that you think you'll be needing hot water. You could set it for 12 hours and you'd have hot water for the next morning and you could reset it before it even expires if you need hot water the rest of the day.
I get it, I just don't see why you can't manage it from the panel alone instead of introducing yet another device that can fail or worse! Given it's age, I would be concerned about safely.
