3607 waste tanks replacement
Re: 3607 waste tanks replacement
Postby km1125 » September 25th, 2020, 9:35 am
Midnightsun wrote:Source of the post Great work, love it when one takes the time to do it right.
Both my tanks have vacuum relief valves on them from the factory. Not that it is required but just adds additional protection against blocked vent or over powerful pumpout units and now is the time to do it before the tank sees it first use. Heck, did not even know this existed until I saw them on my tanks and researched it. https://www.dometic.com/en-us/us/produc ... er-_-25365
That's a pretty cool product and probably a good idea. I actually fitted something like the one below (that's used for under-counter drain vent in a house) to a friend's 480 Sedan Bridge because his marina installed a new "high vacuum" system that was so strong it was deforming his tank and was pulling the hoses off. It adapted nicely to the clean-out port in the top of his tank so we didn't even have to cut into the tank, and it worked great. He had already replaced all the vent system but still had a problem that this solved.
denders
Vessel Info: 1985 Carver 3607 Aft Cabin
Been thanked: 24 times
Postby denders » September 25th, 2020, 10:54 am
Thanks for posting this , I have to get our forward tank monitor working.
Postby bud37 » September 25th, 2020, 11:18 am
Those vacuum breakers work well for what they are.....especially when the system is vacuflush type.....with the the electric toilets there is always a way to get some vent air in to replace the vacuum pull from the pumpout system, which are sometimes set way higher than they need to be to do their job..... :-O
Perhaps if the toilet vents were dual 1.5" the tanks would even work better.....I think some of the newer builds are coming with the larger vents now.
