prop play
- pepmyster
8.1 Volvo Penta
- Has thanked: 492 times
- Been thanked: 210 times
Re: prop play
- Been thanked: 1311 times
Re: prop play
pepmyster wrote:Source of the post Can I get these nuts off using a channel lock style pliers?
Nope.....get yourself one of these bad boys....AARRRRRRR......
http://photos-ak.sparkpeople.com/nw/5/7/l570351108.jpg
- Has thanked: 474 times
Re: prop play
Unlikely. Having said that, if they're loose I suppose you might be able to but that's not what you should be using to reinstall them.pepmyster wrote:Source of the post....Can I get these nuts off using a channel lock style pliers?
Re: prop play
- pepmyster
8.1 Volvo Penta
Re: prop play
Re: prop play
1 1/2" shaft has a 1 1/8" thread and 1 1/4" thread for a 1 /3/4' shaft. Look up standard nut dimension for those and you should be good to go.A 24" adjustable will do the job fine. You only need 1 wrench as you simply block up from the ground with lumber to support the prop blade so it does not turn when you wrench on it.
Re: prop play
- pepmyster
8.1 Volvo Penta
Re: prop play
