1988 Carver 3067 Santego trimming outdrives
- Mowery1
- Vessel Info: 1995 Carver 280 express
- Has thanked: 1 time
Re: 1988 Carver 3067 Santego trimming outdrives
- Has thanked: 602 times
- Been thanked: 1311 times
Mowery1 wrote:Source of the post The boat is in the shop right now getting the starboard outdrive replaced. Impellers replaced in both drives along with gimbals and changing the fluids..Ill check everything out before it goes back into the water..
Hopefully they may pick up on something while they are working on the drives.....I wouldn't assume anything while working thru a problem....cross things off the list one at a time.
Mowery1 wrote:Source of the post The boat is in the shop right now getting the starboard outdrive replaced....
I assume they are reinstalling the drives? If so, do they know about the trim issue? If not, tell them so they can check the trim limit switch adjustment in case that's the problem. If the limit switches have to be replaced, I find it easier to do without the drives in the way.
- theorifice
- Vessel Info: 1987 Carver Santego 30
- Has thanked: 16 times
- Been thanked: 4 times
