New here - need Chattanooga electrician
- Has thanked: 469 times
- Been thanked: 1765 times
Re: New here - need Chattanooga electrician
- HudsonRiver01
- Vessel Info: 1990 Carver Santego 38
- Has thanked: 14 times
- Been thanked: 646 times
- Kramer_cruising
- Vessel Info: 1993 Carver 390 CPMY
- Has thanked: 6 times
When all breakers on the panel are switched to the "off" position, including the main of Shore 1 and Shore 2, the boat actually does receive shore power, as indicated by the blue light on the power cable. When switching on "Shore 1" for example, the meter indicates that indeed power is flowing. But then, whichever individual switch that I flip, be it lights or AC or whatever, it trips, causing the alarm light on the dock to flash and I have to reset that.
I have tried the shore power outlet on my boat slip (50A) and the neighbor's; same result; trip. I have also tried the shore power outlet on the opposing boat slip (same dock) that has 30A. Same thing, trip.
There are 2 shore power inlets on the boat, by the way.
- Has thanked: 598 times
- Been thanked: 1281 times
I had the same issue with one boat, it was a short to ground from a neutral in one of the light switch boxes....took a long time to find it. My opinion for what it is worth.....good luck man.
- Kramer_cruising
bud37 wrote:Source of the post My advice is to hire a marine certified electrician to check it out, I think you were already leaning that way anyhow. This kind of thing if not a simple breaker issue can get pretty involved to explain in a forum. Actually one question, did this only start after you purchased the boat and moved to a different marina. Some of the new marina dock breakers being installed now are touchy on the ground fault side.
Agreed. Just need a trusted recommendation from locals. I’ve not found any recommendations from neighbors at the marina yet.
- Been thanked: 601 times
These are very sensitive to shared neutrals, improper grounding etc. The wiring on these older boats isn't really up to speed with a GFI supply service.
You may have already done this but....
If your boat has dual 30 amp inputs, plug into a single dual 30 amp dock pedestal, not a 50 amp with a splitter, and not 2 separate 30 amp pedestals.
As you mentioned, with all 120v breakers off, switch on main, main number 1 should be everything but your a/c. If the power holds, you have no faults to the panel.
I would then unplug anything from all receptacles, your fridge and ice maker if so equipped are probably on a receptacle circuit, so make sure they are unplugged. Then flip on one receptacle circuit. If power holds. Plug in one thing at a time until it trips. Do the same with all breakers.
items that will most likely cause issues with the GFI are the fridge, icemaker, zinc saver, battery charger, any inverter if installed and the water heater.
Any work you can do ahead of time to isolate the issue, will save you money, as a master electrician will do the same at $100 plus per hour.
Good Luck!
- Kramer_cruising
I am going to be on the boat in Soddy Daisy tomorrow (Saturday, May 15), and I will try to run the generator instead of shore power to see what happens.
If any one of you are in the Chattanooga area and can swing by Harbor Lights to take a more expert look at this issue, please PM me to let me know.
And again, any recommendations for a local electrician would he appreciated.
Thanks!
