Gas tank leak
- Matt1989Carver3807
- Has thanked: 13 times
- Been thanked: 3 times
Re: Gas tank leak
Re: Gas tank leak
Conversation with boat mechanic (a really knowledgeable source) is leaning toward opening the hull from the outside and pulling the tank out of the side of the boat. Will checkout available haul out sites and fiberglass installers.
Next duty is to remove all sources of gas odor which now appears decreasing with just air circulation.
- Has thanked: 603 times
- Been thanked: 1311 times
Re: Gas tank leak
After this repair assuming you go ahead, will you be planning on keeping this boat for long haul ?
- Been thanked: 654 times
Re: Gas tank leak
Re: Gas tank leak
The first time I saw them do this I was amazed and glad I didn't have and aft cabin!
Re: Gas tank leak
Today attention was focused on the forward bilge pump area. There was a slight suggestion of possibly raw gas smell in the forward head. Removing the foot square hatch in the companionway revealed the source of the odor. Pumping out the pump area produced about 2 cups of raw gas and about 3.5 quarts of water which was probably taken on during the haul out when there was an open sea strainer source.
The midships bilge pump area also produced 2-3 quarts of water probably from the same source.
So the only area now to be checked is in the vicinity of the aft bilge pump.
Re: Gas tank leak
bud37 wrote:Source of the post Any fuel that has soaked into the wooden tank support platform etc will regenerate fumes when opened up so still be aware of this..... the hull thing sounds scary but may be the best solution. Only thing to be aware of is the " while were are in here statement "....![]()
1. Keeping the boat is the plan. Hope to make a trip to Oceanside and probably Catalina after some local trips about San Diego.
2. Thanks for the advice to look for wood that is exposed releasing gas/fumes.
3. Am aware of the dangers of the "while we are in here" persuasion". Unfortunately/fortunately we have plenty to keep us busy already.
Re: Gas tank leak
If you still have the original open top shower sumps, make sure they're actually working or they'll overflow and stale water will collect on the outboard side of the starboard stringer in the aft cabin. You can barely see the area through the access under the drawer mentioned above. These open sumps are a source of some of the odor in the boat along with permeated waste hoses. I replaced both of my sumps and am really happy I did. A real pain to replace, especially the aft one, but doable.
Re: Gas tank leak
Considering the expenses involved I am not enthusiastic about addressing the starboard tank as there is no evidence of a problem leak.
Re: Gas tank leak
