Freeze plug is gone. Water in oil.
Been thanked: 1310 times
Re: Freeze plug is gone. Water in oil.
Postby bud37 » June 1st, 2021, 1:00 pm
I think you should should do a little searching around for yourself in your area........just a quick search of marine engines in Texas came up with many possibilities..........the only thing would be if you need a specific rotation, but that can be overcome.
Take some time and ask some questions in your area.
Hans....bread and butter... :-D
Been thanked: 1111 times
Postby km1125 » June 1st, 2021, 2:26 pm
He might be thinking a "reverse rotation" 454, which are harder to come by but not unheard of.
Postby km1125 » June 1st, 2021, 2:30 pm
Here's a std rotation "1990 or earlier" and reverse rotation is $500 more:
https://www.michiganmotorz.com/7-4l-454 ... 90-earlier
Postby Midnightsun » June 1st, 2021, 3:07 pm
km1125 wrote:Source of the post Here's a std rotation "1990 or earlier" and reverse rotation is $500 more:
Thanks for posting Michigan Motors, those guys are well known and have been around forever, would not have any issue ordering from them. :down: :down:
CptBacardi
Vessel Info: 1989 Carver 38 Santego (not an aft cabin)
Has thanked: 3 times
Postby CptBacardi » June 1st, 2021, 6:52 pm
Thank you. I guess the Marina is worried about all the accessories that attach to a new long block as potentially also being damaged... intake manifold, exhaust, etc... which is why they’re recommending new complete 383’s?
Postby bud37 » June 1st, 2021, 7:18 pm
CptBacardi wrote:Source of the post Thank you. I guess the Marina is worried about all the accessories that attach to a new long block as potentially also being damaged... intake manifold, exhaust, etc... which is why they’re recommending new complete 383’s?
Well they could inspect the parts first and have them tested before making a decision like that......forcing you to repower both engines.
I do have one question though......how long are you considering keeping this boat ?
CptBacardi
Postby CptBacardi » June 1st, 2021, 8:13 pm
I really don’t know Bud. At least a couple more years. Slip fees are expensive, if a job situation was to occur I’d probably have to sell.
Postby Viper » June 1st, 2021, 10:16 pm
Should be no problem getting a 454 long block and like I said, if it's a counter rotator you can salvage the parts from the existing engine to reverse it if sourcing one becomes an issue. There also shouldn't be a problem getting all the external hardware if that's damaged too. The marina just has to do a little more homework!
Postby tomschauer » June 2nd, 2021, 12:36 pm
GM still makes and sells new 454 short and long blocks.
Rebuilds are very readily available.
Postby Midnightsun » June 2nd, 2021, 2:13 pm
tomschauer wrote:Source of the post GM still makes and sells new 454 short and long blocks.
Most big blocks were discontinued in 2009 however there are a lot of blocks still available in fact I suspect it will take a decade or more before they start to become rare. https://gmauthority.com/blog/2009/12/sa ... ck-engine/
