3807 Fresh Water Tank Loosing Water
Re: 3807 Fresh Water Tank Loosing Water
Postby km1125 » June 21st, 2021, 8:23 am
Raylap819 wrote:Source of the post Also found a round canister with the words « Water Puppy ». It’s attached to the output side of the pump. Might be a priming thing???
If you can get a picture of that thing, it might be easier to identify it. I'm wondering if it's a a screen and it was erroneously installed on the output side instead of the input side.
If the pump keeps cycling on and off then you either have a leak after the pump or the pump valves have something wrong. It could be something as simple as some small debris stuck in there. Most times you can disassemble the pump head and clean everything and put it together and it will be fine. However, since you're also losing water, it's probably a leak this time.
Been thanked: 285 times
Postby buster53 » June 21st, 2021, 11:29 am
Raylap819 wrote:Also found a round canister with the words « Water Puppy ». It’s attached to the output side of the pump. Might be a priming thing???
Probably an accumulator tank.
Wsullivan71
Vessel Info: 2001 Carver 404 Motor Yacht
Been thanked: 12 times
Postby Wsullivan71 » June 21st, 2021, 2:12 pm
If outfitted, check icemaker. Mine had an old water supply line leaking that caused the pump to run every few minutes and since water was leaking on deck, it was hard to locate.
Postby Viper » June 21st, 2021, 9:54 pm
Ya was thinking an accumulator tank too but that's a lot to try and fit into that little space by the pump. I usually associate "Water Puppy" with a model of utility pump but they may have had other accessories too. The strainer should be in that space plumbed into the line between the tank and the pump. A picture of the "Water Puppy" would help. Is there one or two hoses going to it? An accumulator tank will only have one line hooked up.
BYW, it's way easier to work in that space if you remove the bottom step. They are fastened to aluminum angle brackets on both sides. Look under the step and you'll see the brackets and two screws on each side.
plittle2005
Has thanked: 16 times
Been thanked: 37 times
Postby plittle2005 » July 23rd, 2021, 9:13 pm
See: https://www.westmarine.com/buy/jabsco-- ... v--6619340
Cylindrical shape, but actually a pump.
Phil Little
Postby Viper » July 24th, 2021, 9:18 am
That's a utility pump meant for moving/transferring liquids. It's not ideal for use as a pressurized fresh water pump even if you were to add a pressure switch. It incorporates a flexible impeller which cannot be allowed to run dry. Flexible impeller type pump performance drops off quickly as system pressure increases so they are not meant for the type of pressures required for pressurized water systems. That's why bellows or diaphragm types are the design of choice as they can run dry and can easily achieve the pressures needed.
Lizzie
Vessel Info: 1985 Carver Riviera 28 Aft Cabin
Postby Lizzie » August 8th, 2021, 6:36 am
Late to this discussion but I’m having a water system problem (specifics are yet to be determined) on my 1985 2807. Is there a water system diagram or other resources people might recommend?
New yachters, so lots to learn. :-D
Trenton, Ontario, Canada
Postby Viper » August 8th, 2021, 5:20 pm
Welcome aboard Lizzie. You've posed this question on a couple of other people's threads already. You'll have better luck if you start your own thread and pose the question there. Click on the "AC/Heat, Plumbing & Sanitation" section, then click on the blue "New Topic" button on the left.
Postby Viper » August 27th, 2021, 8:22 am
Ray, did you ever get this resolved?
I finally ended up moving my pump into the engine on the other side of the stairs. Way easier to access and work on. I installed a different pump with higher volume and pressure, works awesome, very happy. The strainer is connected directly on the pump's quick connect port so super easy to remove and service. No more squeezing into a tiny opening in the floor. One more thing off the bucket list!
Sailor66
Vessel Info: 1999 Santego 380
Postby Sailor66 » February 8th, 2022, 6:26 am
After removing the floor covering 3 hatches are access to +- 150 gallons of tankage
