SIGH……..winterization!
Netherlands
Sailor Robbert
Vessel Info: Carver 390 CPMY 1993 with 250 HP
Cummins Diesel
Has thanked: 19 times
Been thanked: 11 times
Re: SIGH……..winterization!
Postby Sailor Robbert » October 12th, 2021, 7:31 am
My boat is in salt water and stays there during the winter, I only drain the fresh water tank and blow my fresh water lines with air and drain the water heater. I have 2 each de-frosters standby in the boat that will kick in at 1 deg. C. Here in Holland at the coast line the temperature will decrease max to -5 C. So the temp. inside the boat will never below 0 deg C.
Always take the boat out of the water in spring to do the necessary maintenance. This works fine for me. But I understand the SIGHHH.... for all you guys in Canada and North-US. Stay safe.
Carpe Diem :pirate: :captain: ;-)
Postby RGrew176 » October 13th, 2021, 12:56 am
Those of us here in North America really cannot leave our boats in the water all winter although those who live aboard do. I feel much safer pulling and winterizing.
Been thanked: 285 times
Postby buster53 » October 16th, 2021, 4:39 pm
Ok, here it is. I have one on all 4 strainers
tonyiiiafl
Has thanked: 601 times
Been thanked: 193 times
Postby tonyiiiafl » October 16th, 2021, 8:46 pm
Is that on the lid of the strainer?
Postby buster53 » October 17th, 2021, 12:16 pm
tonyiiiafl wrote:Source of the post Is that on the lid of the strainer?
Yes, that is the cover for my Perko strainer. That is the small one for my genset. I have the next larger size covers for my main engine strainers. Along with my bucket and a short attached hose, makes winterizing a breeze. With my dock water hose, I can fresh water flush anytime I want as well.
tonyiiiafl
Postby tonyiiiafl » October 17th, 2021, 4:10 pm
I am going to have to drill and tap for next season.
Postby Viper » October 17th, 2021, 7:14 pm
Tony, if it's too difficult for you to drill and tap the lid, you can accomplish the same thing by removing the fitting from the strainer outlet and insert a tee then reattach the hose. Off the top of the tee you would attach your valve and a means to attach a hose. BTW, you need to have a means to cap it off when not in use, don't relay solely on the valve.
tonyiiiafl
Postby tonyiiiafl » October 18th, 2021, 5:11 am
Thank you. I have had that idea also. I would lean towards that with a ball valve and a pipe cap on the end. It will be much easier to take off the cap than try and feed fluid(S) through the top of the strainer. Also, This can be done without equipment running also!
Postby bud37 » October 18th, 2021, 8:46 am
Just a reminder......when adding any fittings to the raw water side, try to make sure you are installing the correct type ( metal).....
tonyiiiafl
Postby tonyiiiafl » October 18th, 2021, 4:58 pm
OH yes, Brass or Bronze.
Users browsing this forum: Google Adsense [Bot] and 56 guests
