Mariner 420 2004 - water in swim platform
- Has thanked: 602 times
- Been thanked: 1310 times
Re: Mariner 420 2004 - water in swim platform
Edit.......is your platform open from inside the boats engine room, check there for where you can visually inspect for leaks....if you have those round inspection fittings on the under side, check the rubber "O" ring to see if they are sealing properly.
It's going to be a pricey fix but it'll be pricier if you let it go for too long.
Where is she located?
- Lruel
- Vessel Info: Mariner 420 2004
Thanks again formthe help
Laurent
- Lruel
Thanks in advance
Laurent
- Lruel
I asked the fiber guy to put some openings that I will unscrew to let the water go out before winterizing, so that if there is still water in the hollow platform it will not freeze and crack the fiber.
- Been thanked: 1111 times
Users browsing this forum: No registered users and 40 guests
