Click Flooring
- ColRon
- Has thanked: 77 times
- Been thanked: 157 times
Re: Click Flooring
“Escape Plan”
Murray, KY
- KyleR
- Vessel Info: MV Verity
2002 Carver 396
- Has thanked: 153 times
- Been thanked: 137 times
Re: Click Flooring
Leaving a gap at the wall present problems as it’s not always straight but curves eliminating using a quarter round strip to cover the gap.
This is the stuff we used when we redid the stairs in our home. The bottom stair had a significant bend requiring a 180deg quarter-round wrap. This worked amazingly for hiding the gap on the bend:
2002 Carver 396
Re: Click Flooring
Kyle, thanks for the tip re the flexible quarter round. I really don't want to leave a gap but if there is no choice it's good to know there are options to hide the gaps at curved areas.
- Tireless
- Has thanked: 183 times
- Been thanked: 187 times
Re: Click Flooring
There are also PVC products that I am considering. Al Stuckless, (Als Marine Service) who is a member of this web site deals with and installs this all the time. It has a teak/holly appearance. Check out his web site. He is located in Kingston, Ontario, but he is the the Georgian Bay Area all the time.
I was on a brand new 60’ Cantius the other day, and they are installing vinyl floors in there boats now. I have decided that wood or laminate is not a good option for us.
Greg
Re: Click Flooring
Greg, what kind of backing are you talking about that can't be glued? They all have a backing material of some sort. Some are up to about 1/4" thick while others are less than 1/8"Tireless wrote:Source of the post ....If the vinyl has a backing on it, it can’t be glued down as the glue would react to the backing.....
- Cooler
- Has thanked: 68 times
- Been thanked: 413 times
Re: Click Flooring
https://marinecarpeting.com/samples-of- ... n-teak-ii/
Hopefully, the video will load showing how easy it cleans. They pour engine oil on it, ketchup & mustard, etc., and it wipes off like magic.
Viper - if this interests you, let me know. If you are willing to drive to lower Michgan, I have a contact for you.
- quickdecision
- Vessel Info: Carver 3807, 1987
- Been thanked: 23 times
Re: Click Flooring
Ron
- Tireless
Re: Click Flooring
The backing are normally a rubber or foam backing that is a problem for gluing down.
Greg
Re: Click Flooring
