1992 36 aft cabin wiring diagram
plittle2005
Has thanked: 16 times
Been thanked: 37 times
Re: 1992 36 aft cabin wiring diagram
Postby plittle2005 » May 4th, 2023, 2:30 pm
Mypleasure, if you will post your email address, I will send you several PDF's of Carver manuals from these years with wiring diagrams and other info. I don't know how to post an 8mb file here.
Anyone else who is interested, let me know. I will send.
Phil Little
plittle2005@yahoo.com
Postby Viper » May 4th, 2023, 3:19 pm
That's not right for sure.
Postby km1125 » May 4th, 2023, 4:50 pm
Is it possible your boat has (or had) an inverter?
That might be a reason why someone might have used a "ship/shore" switch in the manner you describe. NOT as really a "ship or shore" source, but as an easy way to shut down high current devices if they were running on an inverter and re-enable them when the inverter was not in use.
Postby bud37 » May 4th, 2023, 4:53 pm
Remember if this was done by a previous owner/mechanic etc, it is also possible they may have not used the correct color wiring, you will have to get an eyeball on the exact routing if possible......maybe do some continuity tests.
MyPleasure
Vessel Info: 1992 Carver 36 aft cabin with Volvo 740b engines. Westerbeke 5kw generator. Bought the boat in Portland Oregon in June, and a friend and I brought it up to Sidney, BC. Great trip!
Been thanked: 23 times
Postby MyPleasure » May 5th, 2023, 12:44 am
The boat never came with an inverter/charger, and the rotary switch is definitely OEM. The hot water breaker is at the bottom of the breaker panel and worked perfectly until I redid the wiring so that the incoming shore power goes directly to the inverter/charger and then feeds the breaker panel. For some reason I didn’t pay attention to the water heater wiring, so I’ll have to try and trace the water heater wiring from the heater to the panel. You all know what it’s like trying to trace boat wiring when there is only you, and the wiring just has to go through areas where you can’t see where it comes out. My arms just aren’t long enough to find the other end. I’m sure that I’ll find the wire’s tomorrow.
My email is agskinner@outlook.com if plittle2005 can send me that information. I can’t even figure out how to post pictures on this website yet? Computer dinosaur here.
Thanks again fellas, your always a great source of information!
Al
1st Carver 1987 32 Aft Cabin
3rd Carver 1995 350 Voyager
MyPleasure
Postby MyPleasure » May 7th, 2023, 9:42 pm
Got everything figured out once I had my thinking cap on right! Inverter is working as it should and hot water tank is making hot water. Hallelujah!
Thanks again for all the advice guys!
Al
Postby km1125 » May 8th, 2023, 9:25 am
So, what was the issue?? Did you have to change the wiring?
Teamcarp
Vessel Info: 1988 4207 Carver
Postby Teamcarp » May 25th, 2023, 9:23 pm
My Pleasure:
According to your post, apparently you once owned a 1989 Carver 4207, My wife and I currently own a 1988 Carver 4207, and need a wiring diagram for the boat. By chance, do you still have the wiring diagram for your 1989 Carver 4207, and if so, would you be willing to part with it? Please advise. Thanks!
Most sincerely,
TeamCarp
Teamcarp
Postby Teamcarp » May 25th, 2023, 9:31 pm
My Pleasure:
Our email address is TeamCarp17@gmail.com should you need it.
Most sincerely,
TeamCarp
