12V Neutral wiring
Re: 12V Neutral wiring
Postby bud37 » March 20th, 2024, 11:51 am
Wsullivan71 wrote:Source of the post The buss bars are located in the engine and aft bilge compartments and are connected to the transom-mounted zinc plate."
If those bars have only green wires they are for the bonding system connections not for providing 12v returns. The negative system is operationally separate from the bonding side. Yes the 12 volt ground side is connected to the bonding side but only for bonding purposes for example underwater metal corrosion/electrolysis control. Sorry but this is more complicated than can be written in a short post.
Postby Viper » March 20th, 2024, 7:40 pm
Ya you shouldn't be using the bonding system busbars that are located throughout the vessel (green wires as mentioned) for the ground side of DC circuits.
pwillis@mail.com
Vessel Info: 1999 Carver 406
Been thanked: 6 times
Postby pwillis@mail.com » March 21st, 2024, 8:57 am
Thank you Wsullivan71!! And the search continues!!
I really appreciate it. I have to say, that the wiring in the engine room is done really well on my 406. It's neatly organized and covered in a wire management trough. The toilet is working well so far!!
1999 Carver 406 Aft Cabin
Postby g36 » March 21st, 2024, 8:57 pm
My 405 has only the negative bus behind the electrical ac panel at the port side dinette, no fwd bus, that I have ever found. Yourszhould also be there
Postby g36 » March 23rd, 2024, 8:12 pm
Nothing in the stern either only bus is in the electrical panel
