Shower Sump Not Working
Re: Shower Sump Not Working
Cooler wrote:Source of the post I have not had the lid on mine for years. Not aware of why it is even there.er
Helps contain odours for one, that's part of the reason for the seal in the lid. For safety, it helps prevent flooding in the case where the vessel heels over in rough seas and ingests water through the discharge port. While newer model have check valves, they fail eventually and some folks prefer not to have them so they get removed. They also help identify a pump or switch failure. If the pump or switch fails with a lid, nothing will drain as it will back up from having nowhere to go. When there's no lid it just overflows and there's no sign there's a problem until you happen to look into that compartment.
I clean out the shower sumps with some degreaser and a brush as part of winter lay up. Keeps thing working and odour free all season long with no surprises.
If you can easily upgrade it would be the best route to go. The older rule model was a 98A like I have which is replaced by the 98B. Here is a vid comparing the two. https://www.xylem.com/en-us/support/video-library/shower-drain-box-improvements/
- Been thanked: 1113 times
Users browsing this forum: No registered users and 61 guests
er
