Upper helm leaking steering fluid
Been thanked: 413 times
Re: Upper helm leaking steering fluid
Postby Cooler » September 12th, 2024, 11:59 am
Anything is possible. Make sure you check the steering arm located by the rudders for a leak. That is very typical. 8-) er
Merkinbrumsky
Vessel Info: 1985 Carver Voyager
Has thanked: 53 times
Been thanked: 38 times
Postby Merkinbrumsky » September 12th, 2024, 12:11 pm
When I blew the seals on mine I found a very slow leak at the reservoir after reinstalling. There are 2 bleader screws on the reservoir, one needed the rubber o ring replaced. I ended up leaving a piece of paper towel under it when I wasn’t at the boat to confirm bc the leak was so small it rarely dripped.
Merkinbrumsky
Postby Merkinbrumsky » September 12th, 2024, 8:02 pm
This may help if you tackle it yourself.
Postby km1125 » September 13th, 2024, 10:04 am
MCADRG wrote:Source of the post It looks like my upper helm is Hynautic H-52 model. The reservoir is located at the stern of the boat in the aft cabin below the small seat next to the bed. I have searched for a leak/failure and cannot find anything. Could it be possible the upper helm seal simply failed due to fatigue? Thanks Cooler for the fluid advice.
There are a handful of O-rings in there that eventually will harden and allow some leaking. Not really that hard to replace, just have to be careful taking apart and re-assembling. And there are some springs in there too, so be careful when you open it up. Definitely look at videos or follow the threads on this site where folks have detailed info on how they rebuilt theirs.
BarryK
Vessel Info: 1990 Santego 3467
Twin 454 Crusaders
Has thanked: 12 times
Been thanked: 6 times
Postby BarryK » September 15th, 2024, 12:39 pm
Mine was leaking. I tightened the connections a bit and that solved the problem.
Barry
