1990 3807 Head Fresh Water Pump
Been thanked: 285 times
Re: 1990 3807 Head Fresh Water Pump
Postby buster53 » July 19th, 2025, 8:31 am
chuck1869 wrote:Source of the post Thank you buster53 for the replies. One head is a Jabsco. Not for sure on the other. I'll look for the pump this weekend.
Any updates yet?
Postby buster53 » July 19th, 2025, 8:33 am
Any updates yet?
chuck1869
Vessel Info: 1990 3807
Postby chuck1869 » July 25th, 2025, 6:49 am
KyleR wrote:Source of the post
If your fresh water pump doesn’t stop running, you’ve either got an empty tank, the pump is faulty or you have a plumbing leak.
Also, some freshwater pumps, like our Shurflo Aqua King 2, have a pressure switch AND a bypass valve built into the pump, both of which are adjustable via a very small allen wrench. We had an issue with ours running for no reason and I ended up tweaking those setpoints until it operated correctly. There are videos on YouTube showing how to make the adjustment.
Might not be your problem, but definitely something good to be aware of! :-D
Thank You All! I have some clear guidance that I truly appreciate!
Kyle, my buddy has an 01 396. He's the guy that got me into all of this. Been 7 years since then.
KyleR
Vessel Info: MV Verity
2002 Carver 396
Twin Cummins 6BTA 370HP
Has thanked: 153 times
Been thanked: 138 times
Postby KyleR » July 25th, 2025, 7:33 am
So you can blame it all on him!! :lol:
MV Verity
2002 Carver 396
