Well that escalated quickly!
- waybomb
- CYO Moderator
- Been thanked: 491 times
Re: Well that escalated quickly!
Have you looked at the anti siphon valves?
- Jlubas
- Vessel Info: 1995 Carver 355 Aft Cabin
Crusader 454 XLI's
- waybomb
- CYO Moderator
- Jlubas
Crusader 454 XLI's
- waybomb
- CYO Moderator
Remove the hose, unscrew the valve.
It's has very lightly spring loaded ball that close off the fuel tank in case off a hose leak.
The fuel pump had enough suction to overcome this spring and open the valve for flow.
Often they get gummed up and restrict flow. You should be able to blow through it from pipe thread side.
If they look difficult to get to you may just want to buy two newe ones and replace them right away, to save pain and aggravation if you have to squeeze into a tight place to get to them.
km1125 wrote:Source of the post I realize it's POSSIBLE with an EFI system, but much more unlikely **provided** everything is operating like it should be.....
"Provided everything is operating like it should be" works for both EFI and carbed apps. It really doesn't matter whether it's EFI or not. EFI is just as susceptible as carbed apps are on the suction side. Those with Cool Fuel modules help minimize that but for EFI apps that don't have it, they're just as susceptible as carbed units.
km1125 wrote:Source of the post ...I suspect that many of these problems would be traced to defective pressure regulators or a problem in the cool-fuel system.....
My experience outside of poor anti-siphon valve operation and heat is more commonly in the fuel supply lines/system to the engine. Making tight bends, line kinks, adding fittings, additional filters, inline items like fuel flow meters, etc. all contribute to additional vacuum which has proven more likely the culprit in my experience. You can put a band-aid on it by doing other things to overcome one of the contributors like cooling the engine compartment but you may be ignoring the true cause if you don't assess the system properly. It may simply be one too many fittings pushing enough restriction over the edge enough to cause too much vacuum.
mjk1040 wrote:Source of the post ....Anyone know where the Oberg is located for the rear auxiliary tank, I do not recall seeing it?
There is no separate one for each tank, it's the same one on the engine that is used no matter what tank you're drawing from, at least not that I've ever seen.
- Jlubas
waybomb wrote:Source of the post They are at the fuel tanks. They look like a hose barb where the fuel hose connects to the tank.
Thank you so much! Very helpful I didn't even know they existed. I will check them out next weekend when I am back down.
Crusader 454 XLI's
- mjk1040
- Been thanked: 248 times
