Small boat and Titanic same problem!
- hardchines
- Vessel Info: 1980 Carver
2667
Santa Cruz - Has thanked: 8 times
- Been thanked: 29 times
Re: Small boat and Titanic same problem!
Pics of hull getting outdrive in my thread "small boat big big project"
- hardchines
2667
Wrote a response to Vipers and your post, It disappeared when I it submit, if it does not appear later I will re-write it later!
- Been thanked: 1113 times
hardchines wrote:Source of the post well if the rotation was counter clockwise I would have done the last 1000 miles going backwards!
Well, if true, then THAT would certainly explain the handling and wander issues!!!
- hardchines
2667
hardchines wrote:Source of the post well if the rotation was counter clockwise I would have done the last 1000 miles going backwards!...
The drive is labeled that it's counter clockwise. Has that been changed and the label is wrong? If so, you may want to change the label as that might throw someone off in a future repair.
I asked about gimbal bearing replacement because I still see the grease nipple on the side of the transom assembly and Merc stopped supplying the greasable bearings ages ago. The new bearings are supplied with a plug to replace the grease nipple.
- hardchines
2667
I must say you guys pay attention to the details good catch on the zerk!
