Thanks guys! Any idea what breaker this one is??Welcome to Carver Yachts Owners Forum
Which bilge pump switch?
- CptBacardi
- Vessel Info: 1989 Carver 38 Santego (not an aft cabin)
- Has thanked: 3 times
Re: Which bilge pump switch?
Thanks guys! Any idea what breaker this one is??- CptBacardi
Those breakers do fail, but not often. I would remove the load side wires, reset it and check for voltage on the load side.
- Has thanked: 602 times
- Been thanked: 1310 times
..- CptBacardi
- Been thanked: 1111 times
CptBacardi wrote:Source of the post
Of course I pulled a freakin wire out the crimp trying to get it off.
It's actually a GOOD thing that you pulled on it and pulled it off, requiring you to FIX it. If you can pull a wire out of a crimp, then the crimp was no good to begin with, and would likely be causing voltage drop and intermittent connections down the road!
- CptBacardi
Did you happen to get a new float switch as well ?
- CptBacardi
