80s 3697 Generator Location
- waybomb
- CYO Moderator
- Been thanked: 490 times
Re: 80s 3697 Generator Location
Please post your efforts in this project!
- BenTen
- Vessel Info: 1984 Carver 3697 Mariner - "We'll Sea"
- Has thanked: 20 times
- Been thanked: 32 times
waybomb wrote:Source of the post The ac line from the genny runs along the forward wall of the engine room to the starboard side, under the boats power inlet. Inside the cabin, in theaft starboard seat area is this little compartment that houses the automatic switch between shore and genny power.
So the Carver I bought has this box under the seat. Could this box do anything else or in addition to housing the transfer switch?
Ben in SC
- waybomb
- CYO Moderator
Follow the wires. Maybe the word are already on the forward wall ready for a genny.
- BenTen
Ben in SC
- waybomb
- CYO Moderator
Climb into the center of the engine bay with a small flashlight, if you go slow, you can actually get over the transmission and almost to the outside. From there you should see the wires from the power inlets, the wires from the relay box to the breaker panel, and probably a coiled up wires that would go to the genny.
- BenTen
Another question: Does the genset use the same exhaust exits at the engines, or it's own, through the hull?
Ben in SC
- waybomb
- CYO Moderator
Pictures are kinda hard to capture in tight spaces
- Has thanked: 602 times
- Been thanked: 1311 times
BenTen wrote:Source of the post Well that's one less thing to do when I add the gen. If the sea cock is there I'll feel much better, though!
One thing I might consider if I was going to install a new gen.....consider an 1800 rpm model,as opposed to the 3600 rpm ones....the 1800 are quieter ,easier on parts etc....good luck man....
- BenTen
Can anyone tell me what the hull thickness is in the rear between the stringers? I'm looking to add a through hull raw water pickup for the future generator before we launch the boat on Tues/Wed and need to order the correct size and length.
Fred: Would you be able to get me a few measurements on the location of the through hull in the picture you posted? Distance from transom, from stringers, side of boat etc.? I can't orient myself exactly as to which is front and rear.
Also, what size is the through hull, 1" or 1-1/2"?
Thanks!
Ben
Ben in SC
