air conditioner replacment
Been thanked: 413 times
Re: air conditioner replacment
Postby Cooler » February 18th, 2019, 10:37 pm
DD - I assume you are referencing the CLF code? That happened for me in cooling cycle only. Last fall, I needed heat, and everything ran fine then. Produced plenty of heat in reverse cycle, so I should be fine after I cleared out air flow blockage. (big bag of rags) Did you get the bad unit removed? 8-) er
Dymonddan
Vessel Info: 1995 Caver 355 Aft Cabin
Postby Dymonddan » February 18th, 2019, 11:01 pm
No sir,
Son was busy, maybe next weekend.
I did remove the bench seat boards to gain access to the duct though.
Postby Midnightsun » February 19th, 2019, 5:33 am
Cooler wrote:Source of the post Hey all, correction to the blower size. The current unit has a 7" outlet. I do not know what the new unit would have. A 6" outlet would be for a 12,000 BTU. 8-) er
If you look at the link of the unit I posted which is the unit he ordered, dimension G is the blower outlet which is 6". 7" does not appear until their 20,000 btu units. ;-) Regardless, if the older unit is 7" then an adapter will be required. Looks like HD has one if so required. https://www.homedepot.com/p/7-in-to-6-i ... /100117561
Dymonddan
Postby Dymonddan » March 3rd, 2019, 8:25 pm
Well, bit the bullet and got the marina to replace the air conditioner unit with the one I purchased.
They did a great job and charged me 6.25 hours labor which I think was good deal.
They put the dinette seat back together as well.
New unit works great.
Thanks guys for all the support and suggestions.
Postby Cooler » March 4th, 2019, 5:32 pm
That was smart! Now you have the marina to go back to if anything happens in the short term. You're still way under that original $4800 expense, and you threw some business to the marina. Hope they charged off-season rate. Everybody wins here! 8-) er
Postby tomschauer » March 4th, 2019, 9:56 pm
6.25 hours seem more than reasonable to me. Sounds like you did pretty well.
:approve:
