Kohler 7.3 Cooling issue
- smcguckin27
- Vessel Info: 2004 Carver 360 Sport Sedan.
- Has thanked: 8 times
- Been thanked: 9 times
Re: Kohler 7.3 Cooling issue
Once I did that, I ensured I cut the zincs short and just checked them more often.
Of course I'm betting you don;t go through zincs like I did in the salt water, but if you have them in the HX, I'd check those elbows just to be sure you are getting full water flow.
Good Luck.
- 650Guy
- Captain
- Been thanked: 40 times
- Helmsman
- Has thanked: 73 times
- Been thanked: 42 times
- Keith S
- Vessel Info: 2005 38 Super Sport
- Been thanked: 21 times
- 650Guy
- Captain
Here is my plan:
1). Install new thermostat
2). Refill coolant as it’s been drained as I was searching for thermostat parts in said engine. So with that in mind, I shall fill the coolant with cap off
3). Run gen and watch quantity filling as needed.
4). Once stable, shut engine down.
5). Install cap
6). Run engine again and bleed using bleed screw.
7). Shut down
8). Change oil
9). Start gen
10). Drink beer
11). Pray she stays running.
Anyone see any flaw in that process?
- Keith S
- 650Guy
- Captain
- LES DOIT
- Vessel Info: 97 Carver 350 Mariner
Twin FWC Crusader 5.7 XL HT - Location: Fort Myers
Marina did some other work on the engines for me and when I pick the boat up first time on plane raw water hose blew off on port engine and it shut down. When it shut down it decelerated both engines and appeared the genset cut off to. If port engine shuts down will it shut off the genset at the same time? This just happened yesterday and the boat is back at the marina so I don't know if my generator issue is solved yet or not.
- Keith S
- 650Guy
- Captain
Again, Thank you all for the help and suggestions! The were key to me getting her up and running!!
