Limited RPM's
Re: Limited RPM's
I have a marina neighbor with the same boat, same year, and same power. He always runs full fuel and water and usually a crew of 8. He pulls two tubes behind the thing without issue. Last year he had the same problem. We found one of the engines had a fuel pump that wasn't delivering the proper pressure. The other couldn't compensate. New pump and regulator, back to pulling tubes and top speed of 35mph. The little thing moves along!
- Marty
- Vessel Info: 2000 326 AFT Cabin
- Has thanked: 16 times
- Been thanked: 9 times
Re: Limited RPM's
Re: Limited RPM's
BTW, my 355 cruises at 24-25 and will do 31. Your boat should go much faster than mine.
- Marty
Re: Limited RPM's
- Has thanked: 603 times
- Been thanked: 1311 times
Re: Limited RPM's
Marty wrote:Source of the post I've owned the boat since summer of 18' and max speed I've seen with a 5 footer pushing me is 25MPH (w/o 18-20). I think I need to hire an outside specialist/marine mechanic to bring my vessel up to speed (no pun intended).
That is quite possible but who.....may I ask were you happy with your boats performance previous and are you back to that now.
I believe you can get into a very expensive cycle here trying to attain max performance that you never really use.....
To add, this is just my opinion, of course it is always up to you how to proceed, there may be other views that make more sense than mine. Good luck with it going forward....tall ships this weekend.....
- Marty
Re: Limited RPM's
Weight may be a bit of factor, but seeing as how performance is getting progressively worse it has to be fuel/air related I'm thinking....
Re: Limited RPM's
Marty wrote:Source of the post Weight may be a bit of factor, but seeing as how performance is getting progressively worse it has to be fuel/air related I'm thinking....
Yup , you may be stuck going thru your equipment considering its getting worse.
Marty if you find a good mechanic, I would be very interested to know.
