Need help troubleshooting Alarm on 8.1L Horizon engines
Has thanked: 603 times
Re: Need help troubleshooting Alarm on 8.1L Horizon engines
Postby bud37 » September 10th, 2019, 3:56 pm
mhanch wrote:Source of the post
bud37 wrote:Source of the post So because there is some discussion about the fluid........when you checked the fluid before you changed it....how would you describe the color on the dipstick.....pinkish,used oil color,or honey color.?
Do you have v drives with the trans/drive ( no shaft between ) attached directly to the back of the engine ?
Starboard was Used oil color with some pinkish color, Port (with the alarm) was used oil color with almost no pink. Both are straight drive (no v drive).
After the flush and running, I checked both again and they are pink, no used oil color.
Ok , good........some of the shared sump v drive apps in those years used a different oem hydraulic fluid....I was just checking..... Agian good luck and P.A.C.E...... :-D
mhanch
Vessel Info: 2000 Carver Voyager 374
Twin Gas Mercruiser 8.1L Horizon engines (2007 Repower)
Has thanked: 5 times
Been thanked: 6 times
Postby mhanch » August 10th, 2020, 11:54 am
Update: the alarm came back a few weeks ago. The local Mercruiser shop couldn't figure i tout, so I hooked up the Vessel View and ran a bunch of test runs while recording the data. it turned out that the Cooling water pressure sensor was starting High with the engine off, and slowly showing a drop in pressure to zero. however you could see constant water flow out of the exhaust. so the sensor itself was failing. Apparently this is common to this sensor, and it took ordering a few to get a good one.
Once installed, it's running rock solid. having the Vessel View mobile to test this our was amazing. would never have figured it out otherwise.
Postby Viper » August 10th, 2020, 9:19 pm
Love the Vessel View Mobile. Happy it helped solve the problem :down:
