98 model 405 hot water heater
Re: 98 model 405 hot water heater
Postby g36 » December 19th, 2020, 12:38 pm
I have the same pic of me sitting in the space when changing my water heater. My wife got the idea to quickly reassemble the bed and leave me in there. I only wish I was 195lbs im at about 230. Glad you got it all straightened out now.
Postby Viper » December 19th, 2020, 9:43 pm
Good job. I think you know what I mean now when I tell people that accessibility is everything in determining how much it'll cost to repair something.
kgarguilo
Vessel Info: 1999 Carver 406
Has thanked: 197 times
Been thanked: 55 times
Postby kgarguilo » April 25th, 2023, 7:01 pm
Very good documentation on this Water heater swap. I have just ordered a replacement for mine a 99 model Seaward S1100. Question, you stated coolant came out of the heat exchanger lines that fed the water heater. Do you have a closed loop system instead of raw water cooling? Also, good to know that is where the spitting and sputtering is coming from as that is irritating. Thanks in advance for any info you can share regarding type of cooling system.
Kevin G.
1999 Carver 406
Postby Viper » April 25th, 2023, 9:28 pm
If the engine block is cooled with coolant (fresh water cooled, closed cooling) then that is what will be going through the hot water heater heat exchanger.
kgarguilo
Postby kgarguilo » April 26th, 2023, 7:23 am
Thanks, the comment "covered in coolant" had me concerned I was missing something.
Kevin G.
1999 Carver 406
