How many shaft anodes?
Re: How many shaft anodes?
Postby mjk1040 » April 3rd, 2021, 4:36 pm
I think Viper may have miss spoke on which type to use where. I believe I was told zinc for salt water, magnesium for brackish water and aluminum for fresh water. I tried to get aluminum engine anodes and was told they were not cost effective and thus not offered and to use magnesium. Check all your engine anodes too. I believe those people at boatzincs know their stuff!
Great Britain
PossiblyPaul
Vessel Info: Hornbill III
1988 Carver 2827 Voyager,Volvo Penta TAMD31 engines.
Ardglass Marina, County Down
Has thanked: 48 times
Been thanked: 6 times
Postby PossiblyPaul » April 3rd, 2021, 6:51 pm
Very interesting discussion above. Replacing all of my zinc anodes this month (finally) I went with the leading provider (so I'm told) in the UK, who advised aluminium for all of them, and I've added a couple of rope-cutter combinations to the shafts.
I'm in a small coastal marina, mainly sailboats but with a number of motorboats, and a fishing harbour close by. I have a suspicion that the screws holding the trim-tab plates were - very quickly - eroded more by electrical effects than anything else, and the resultant holes in the hull damn near sunk the boat last year; a very close watch on that this year!
Funga Safari
Postby Viper » April 3rd, 2021, 7:44 pm
Viper wrote:Source of the post....mag for fresh water and aluminum for salt and brackish....
mjk1040 wrote:Source of the post I think Viper may have miss spoke on which type to use where. I believe I was told zinc for salt water, magnesium for brackish water and aluminum for fresh water......
Nope, I got it right! Aluminum anodes are for salt and brackish water, magnesium anodes are for fresh water only. The growing trend is to move away from zinc for salt water. And as I explained above when considering the metals involved in the application's running gear, aluminum can be used on fresh water inboards too as it'll be more active than the shafts, rudders, and props. Because sterndrives and outboards use aluminum casings, I prefer magnesium anodes for those although the alloys in aluminum anodes are still more active than the alloys used in the sterndrive and outboard casings.
V12diablo
Vessel Info: 2001 Carver 356 Aft Cabin
Been thanked: 13 times
Postby V12diablo » April 3rd, 2021, 9:31 pm
Is there anodes on the Mercruiser 7.4 MPI engines, if so where would I look?
Jason
Postby Viper » April 3rd, 2021, 10:26 pm
Not normally unless it's closed cooled and the type of heat exchanger you have has one.
V12diablo
Postby V12diablo » April 4th, 2021, 12:07 pm
It is closed loop, I’ll check the heat exchanger out.
Jason
Postby Viper » April 4th, 2021, 2:40 pm
Go to the link below and enter your serial number. It will give you a parts breakdown. If you don't have the serial number, go through the directories on the left until you narrow down your model. The serial number is the best way though to be sure.
https://www.mercurymarine.com/en/us/parts-and-accessories/parts-catalog
