No power to port side panel AFT 1983 Carver 28 Mariner
throwback2
and a few other water toys
Has thanked: 8 times
Been thanked: 23 times
Re: No power to port side panel AFT 1983 Carver 28 Mariner
Postby throwback2 » September 21st, 2021, 6:28 pm
Mccurdyj wrote:Source of the post Ok thank you. Where do they hook up on each engine?
You will have to follow the battery cables,mine were across the bell housings
Mccurdyj
Vessel Info: 1983 Carver 28 Mariner
Postby Mccurdyj » September 30th, 2021, 9:27 am
Harness was basically completely disconnected. Plugged in and fired up :-( thank you all for all your help. Could not see the back side of the harness plug because it was behind a coolant line
Has thanked: 603 times
Postby bud37 » September 30th, 2021, 10:18 am
Mccurdyj wrote:Source of the post Harness was basically completely disconnected. Plugged in and fired up :-( thank you all for all your help. Could not see the back side of the harness plug because it was behind a coolant line
Thanks for posting, it is always great to see the resolutions to these problems, generally the simple solutions are the ones......curious...was there anyone working around that area before this happened ?
