V A C U. FLUSH
Re: V A C U. FLUSH
Postby Midnightsun » July 17th, 2022, 8:07 am
Viper wrote:Source of the post I believe 5 hours minimum between cycles is the normal spec
The Carver is my first experience with Vacuflush so not an expert by any means. In all the years I have owned her, the pump has never cycled on it's own unless there was paper in the bowl preventing a proper seal. Not sure where the 5 hour cycle spec comes from. Maybe the older units?
Glad to hear you got her fixed, always a nice feeling of self satisfaction when one finally nails it. :down:
tonyiiiafl
Has thanked: 601 times
Been thanked: 193 times
Re: V A C U. FLUSH
Postby tonyiiiafl » July 17th, 2022, 8:18 am
For sure. I don’t think I did anything out of order either as I didn’t have a gauge. Duck bills first then down the line.
Re: V A C U. FLUSH
Postby Viper » July 17th, 2022, 8:58 am
Midnightsun wrote:Source of the post
It's a minimum spec as mentioned. If you complained that your unit cycles every 5 hours, they would say it's working within normal operating parameters. That's not to say that it can't go longer than 5 hours without cycling but they have to assign a minimum benchmark.
Re: V A C U. FLUSH
Postby km1125 » July 17th, 2022, 9:08 am
tonyiiiafl wrote:Source of the post
... Only issue that may haunt me is I had no silicone grease to lubricate the o rings, so I had to improvise with a silicone lubricant I had on board. ...
I'm not a big proponent of Silicone greases, but they're fine for some applications (such as this one). Another great alternative is Teflon grease, which you can get inexpensively at any hardware store. It's also the grease that's recommended for plastic zippers, so it's good to have aboard.
tonyiiiafl
Re: V A C U. FLUSH
Postby tonyiiiafl » July 20th, 2022, 9:26 am
CASE CLOSED…for now! Unit has been shut off since Sunday, Came down this AM at 4:00AM and turned the switch on. Pump never came on. I am closing the book on this successful repair. That is all!
Re: V A C U. FLUSH
Postby Viper » July 20th, 2022, 6:29 pm
Glad we found the problem :down:
tonyiiiafl
Re: V A C U. FLUSH
Postby tonyiiiafl » July 20th, 2022, 8:30 pm
Me too. I don’t like being beaten.
Moonbeam
Vessel Info: Carver 3207 aft cabin
Re: V A C U. FLUSH
Postby Moonbeam » July 27th, 2022, 6:03 pm
Hello ALL. I just signed up on this site. I have a vacu flush issue to discuss but I see nowhere on the site to create a new post. Where is the magic button to create a new post??
This is Moonbeam
Carver 3207 1985
Re: V A C U. FLUSH
Postby km1125 » July 27th, 2022, 6:23 pm
Moonbeam wrote:Source of the post Hello ALL. I just signed up on this site. I have a vacu flush issue to discuss but I see nowhere on the site to create a new post. Where is the magic button to create a new post??
This is Moonbeam
Carver 3207 1985
tonyiiiafl
Re: V A C U. FLUSH
Postby tonyiiiafl » July 27th, 2022, 6:34 pm
Also vacuflush off since last Saturday. Turned on and no leakage. Yep I won.
