99 MerCruiser 454 L29 in Carver 406 - Failed to stay running then OK
kgarguilo
Vessel Info: 1999 Carver 406
Has thanked: 197 times
Been thanked: 55 times
Re: 99 MerCruiser 454 L29 in Carver 406 - Failed to stay running then OK
Postby kgarguilo » July 9th, 2023, 10:20 am
by Viper » July 9th, 2023, 9:21 am
I assume you have fresh fuel? Have you checked the filters to see if they have any water or a lot of sediment? Have you looked to see whether you have spark at a plug when the engines won't start?
Fresh Fuel
On 6/16 Took on 135 gallons of fuel between all three tanks
Aft 53 gallons of 145 gallons
Port 39 gallons of 99 gallons
Starboard 43 gallons of 99 gallons
Fuel Filters
Only about 20 hours old
No, I have not looked yet. But, they start and then drift back down to 0 RPM's. Then they run all the way back to the dock,
Kevin G.
1999 Carver 406
kgarguilo
Postby kgarguilo » July 9th, 2023, 10:32 am
by Midnightsun » July 9th, 2023, 9:25 am
My gut is telling me your batteries are done and engine electrical is insufficient to run them correctly. Your voltage at 12.4 if correct and taken while engines are running, is way too low, should be around 14 or better with healthy batteries and good alternators.
You pulled anchor and lost engines? The juice required to pull anchor is rather large so I assume it took everything away from the engine requirements and further drained the battery/s resulting in a no start after anchor was up.
I agree with the anchor draw and the thought. I am guessing the codes from the engines will uncover that but, the batteries are new (installed 1/30/23) and levels are full. Qty 2 Interstate Model SRM-31 Dual purpose battery & Gen Battery Interstate 24M-RD (Installed 12/28/22)
Kevin G.
1999 Carver 406
Postby bud37 » July 9th, 2023, 10:51 am
I can tell you that the draw from the windlass on a low battery system or one with not enough capacity will drive the engine ecms nuts. Good practice is to have the engines running while running the windlass at slightly over idle for that reason unless you have a large battery bank with lots of reserve capacity.
I agree with the others and as I mentioned earlier that the 12.4 volts is a serious concern....also only 13.8 approx with engines running needs to be investigated, new batteries or not, something is amiss or not connected properly.
Postby km1125 » July 9th, 2023, 10:56 am
kgarguilo wrote:Source of the post
[b]NOTE: Voltage again was at 12.4 at Helm Garmin on the way back was up to 13.8
To me, this is a pretty key piece of data. That the Garmin was showing 13.8 while you were cruising means it's reading the battery voltage pretty good. might be off a little, but it's close. That means the reading at 12.4 was pretty accurate and does mean the batteries were pretty discharged.
On the batteries... Where they EVER discharged till dead? When was the last time they were tested? You might go through all the connections (both positive and NEGATIVE) and make sure they are all clean and tight.
If, while cruising, you were still reading 12.x something then I'd just think there was some extra voltage drop to the Garmin, and not anything unusual, OR that you had a charging problem, but that doesn't seem to be the case.
Postby bud37 » July 9th, 2023, 11:03 am
Perhaps the alts are not functioning or check those circuits for isolators/ charge management devices.......should see well over 14.5 volts charging from engine alts, even higher on low batteries.
Postby km1125 » July 9th, 2023, 11:42 am
bud37 wrote:Source of the post Perhaps the alts are not functioning or check those circuits for isolators/ charge management devices.......should see well over 14.5 volts charging from engine alts, even higher on low batteries.
Not sure I 100% agree with this. I've don't think I've ever seen much over 14.2 VDC on any of the boat's I've had.
But, the OP should verify that BOTH engines are charging when running. Start each engine alone and see if the battery voltage gets above 13V. It's possible only ONE of the engines is supplying charging while both are running but you won't know it unless you test them individually.
kgarguilo
Postby kgarguilo » July 9th, 2023, 12:48 pm
I will answer all in the order to avoid many entries:
I typically motor forward as I raise the anchor and neutral as I get closer to above anchor to raise it the rest of the way typically 30-40 of water. I understand what you are saying here through.
connected properly.
Guessing the Computer will say for sure what is going on.
Agreed that is why I posted it seems like it should have been higher like 13.8
These batteries have always performed great and never even close to full discharge. I can test them on Monday as I have a tester. Last week I went through and looked and connections on all three batteries positive and negative, all are very clean and tight. No corrosion anywhere.
Agreed
This task may be over my head. If it comes to this I think I will let an expert handle this one.
I can do this on Monday as well and report back. I am guessing it would not matter what battery I am on as long as I start and run one engine and monitor the Helm gauges for over 13 volts, correct?
Thank you all, this is such a great group. Have a great afternoon
Kevin G.
1999 Carver 406
Postby bud37 » July 9th, 2023, 2:08 pm
km1125 wrote:Source of the post Not sure I 100% agree with this. I've don't think I've ever seen much over 14.2 VDC on any of the boat's I've had.
You probably did see just that , Knowing you from here I am guessing you always had a properly charged good condition bank and system, then that is what you would see approximately. Charge voltage will always fluctuate with battery state of charge and system integrity.....no debate, he needs to cross some things off the list then we will all see after his guy checks things out.....at this point it is all assumptions and speculation.
kgarguilo
Postby kgarguilo » July 9th, 2023, 6:23 pm
I was able to make it up to the boat today. I think I see what is going on but would love the input of the folks on this thread to offer input.
One Drive Folder - https://1drv.ms/f/s!AsUXzq27eR2fgrtFI3Thi5fdYVyFOA?e=Q9RSkF
My Pics form today, I hope they make sense in the order I took them and the story it tells is as follows:
• Checked Battery 1 = In the green zone GOOD
• Checked Battery 2 = In the green zone GOOD
• Checked Battery 3 GEN = In the green zone GOOD But lower than the other 2 batteries
Before starting the first (Starboard) engine, I noticed after being on the house charger for well over 24 hours, the voltage at the Garmin (Direct connect to Battery 1) the voltage was at 12.7V. After starting it went up to 13.6 on the way to 14.0 V being charged by the Alternator. The voltmeter indicates over 14V. Of course, the house charger (60 Amp Charles Charger) while the engine was running is at “0” as expected. I then turned off the starboard engine.
Next, I moved to the Port Engine, the voltmeter also indicates over 14V. The Garmin reflects 13.8 V and then up to 14V.
Next, I started both Engines looks like the helm gauge is higher closer to Port 14.6 / Starboard 14.4ish? The Garmin is solid on 14V.
Two videos on the folder also watch the Garmin.
:19 second video After engines off – Watch voltage go down to 13.2 V and stop there.
1:19 Video while engines running watch Voltage go up
I also learned and is visible on pics a #6 cable runs off of battery 1 to the helm that powers directly Stereo, Amps, Garmin, etc.
I am guessing, the charger is not fulfilling its obligation to keep the batteries up to a higher voltage of 13.8 or higher.
Kevin G.
1999 Carver 406
Postby tomschauer » July 9th, 2023, 8:11 pm
If that Charles Charger is original, keep an eye on it. They usually tend to overcharge and cook your batteries when they are on the way out.
