they have the 30amp and 40amp version ready to ship. So with 40amp, if it is charging only house battery because the other batteries are full, 40 amp should be more than enough to charge 1 battery, right? is that correct understanding? Also km, granted mine is 2000 model, does what you explain above apply to this old version you think?Welcome to Carver Yachts Owners Forum
121805eg c-charger 5000 out of commision
- cpoint
- Has thanked: 208 times
- Been thanked: 32 times
Re: 121805eg c-charger 5000 out of commision
they have the 30amp and 40amp version ready to ship. So with 40amp, if it is charging only house battery because the other batteries are full, 40 amp should be more than enough to charge 1 battery, right? is that correct understanding? Also km, granted mine is 2000 model, does what you explain above apply to this old version you think?-
Bottom line, regardless of what you currently have, you must confirm that the existing wiring will handle full charger output through each one of the charge legs of the new unit if you're going with a ProNauticP Series charger. Check the length of the longest charge output circuit wires to the battery and back (pos/neg) then check what gauge it needs to be to handle full output and use that gauge for all output legs and your negative wire. You can go with one gauge smaller wire for bonding. If your existing wiring falls within this gauge or is bigger, then you're good to go. Consider that the location of the charger needs to be close enough to the house bank so that the temp probe can reach that bank's negative battery post.
- Been thanked: 1113 times
40 is "sufficient", 50 or 60 is better, and anything above that is just "preparation in case you get a larger house bank".
- cpoint
- cpoint
- Has thanked: 602 times
- Been thanked: 1311 times
As I have already said, you have an 80 amp system there now so unless someone before has done something it will be an straight switch except for the extra bonding/case wire....follow the instructions.
To add....if you see any sign of corrosion on the wire/cable connectors ....good practice would be to change for new.....good luck.
- cpoint
Also I am attaching some pictures I found and info on battery below. The old pic shows the AMP around 50 while it was charging I guess. I am not sure what it was charging how many it was charging at the time. Also old picture of batteries in their location. strange location bilge to put batteries in, but lucky for me, it's always dry.
Question....do you have an inverter connected anywhere onboard ?
Nice and clean down there nIce....
- cpoint
bud37 wrote:Source of the post Looks more like about 35, even accounting for parallax, but those little meters are not the best.....like you said you have now way of telling what was on at the time.
Actually thats old pic, much cleaner now
Not sure about an inverter. Not that I am aware of. Good news is west marine just said it is being shipped (50amp), so not going to 40amp.Who is online
