vacuflush leak and smell in head unit
- cpoint
- Has thanked: 208 times
- Been thanked: 32 times
Re: vacuflush leak and smell in head unit
- Has thanked: 602 times
- Been thanked: 1311 times
- cpoint
bud37 wrote:Source of the post I think that by posting that pic you have shown the problem.....the thru hull with the blue handle is open and allowing water to leak back into the system thru the pump and Y valve .....maybe there should be a check valve in that set up.....anyway just close the thru hull valve ( handle 90 degrees to direction of flow), I bet no more water.....
I was thinking about that, was not sure which way way open and which way closed. So this is open, that would explain
If you're in an area where you need to be winterized, get rid of the overboard discharge system altogether or it will come back to haunt you. What ever you do, don't leave the seacock closed for the winter.
- cpoint
- cpoint
- mjk1040
- Been thanked: 248 times
- cpoint
mjk1040 wrote:Source of the post Cpoint it should be in the aft cabin under the carpet and under the second removable panel toward the door to the aft cabin. Make sure in the head that the vacuflush system is in the run mode and not the sleep/silent mode. Are you using a good tank additive for smell etc? If the system is in the sleep mode less vacuum in system and you will get smell if flushed, the admiral pulled that one on me just last week! Also I have suspicion there are charcoal filters on the waste tank vents that to date I have not located, but believe I read in a manual they should be replace annually, if I find them I'll update with the locations or maybe someone else may already know where they are and help us both out. MIKE
Thanks Mike. I do not believe there is any opening under carpeting in aft cabin. There is a panel sort of in the middle of the wall. I opened it, but there was sponge like material covering a tank, assumed it was gas tank (based on documentation/drawings), next to door of aftcabin I will have to take a look again, I did not notice any openings when I was there. About the silent/sleep mode, did not know anything about that. How do you turn that on/off? or know it's setting? And in regards to filter, please post here if you find it. Thanks.
- mjk1040
- cpoint
As far as carver parts drawings, I do not think they are accurate, I am looking at the drawings and they are not matching real location on my 356.Return to “AC/Heat, Plumbing & Sanitation”
